Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Wallace Gear for WM J-3 Cub ARF….
Reply
Old 08-17-2008, 02:14 PM
Dick T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wallace Gear for WM J-3 Cub ARF….
For those of you contemplating Bill Wallace’s scale gear ( http://www.piperj3gear.com/) for the World Models 1/3 scale J-3 Cub ARF, here is my experience thus far.
It takes a little time to get the gear from Bill so plan ahead. He fabricates these in his off time from a full time business. Mine took about 7 weeks from placing the order. However Bill communicated status, delays, etc., via email so I knew what was happening.
The gear arrives partially assembled and in gray primer. I chose to disassemble and paint it matching Cub yellow. I used TopFlite Lusterkote White Primer and Cub Yellow. It takes little primer to cover well but as with most yellow paint, it takes a ton. Used one can for the gear alone. It takes a lot of coats to achieve the golden yellow color and the match is close to the WM Toughlon covering.
Parts of the gear are hidden from view so minimal painting can be done. I didn’t think about this until part way through so coated the to be visible parts heavier.
The side struts were then covered with matching Toughlon film. I made a paper template by fitting and trimming until it fit well when taped to the strut. Transferred that to stiffer material and cut the Toughlon. Used a trim sealing iron to attach it to the strut following up with a larger covering iron. Wrapping, trimming and sealing needs to be done carefully with alternating irons as the metal pulls heat out of the irons quickly. Lastly the Toughlon was shrunk using the large iron only.
Once finished the mismatch of color became more evident at the pivot points and around the axel hub. I brushed on Testors’ #1114 bottled enamel which proved to be a perfect match. I had tried the spray can version of this paint prior to the Lusterkote but found it to be no better in the spray version. Overall for spraying the Lusterkote is more cost effective. The bottled paint is perfect for coating and touching up small areas as the paint can be applied full strength and heavy so it flows together.
The gear was reassembled using the supplied bolts and lock nuts. Silicone grease was applied at all pivot points and the telescoping portions.
Bill supplies a wad of rubberbands and two sewn leather boots with velcro enclosures. Other manufacturers use ‘O’ rings for the bungees. ‘O’ rings are made for compression so I’m not sure how long they will last. I prefer the multiple rubber band method at this point as it provides some backup plus an adjustable method for varying finished airframe weights. Small bungees may be an option too.
Overall the project took about 10-12 hours spread across a week or so, primarily to let the paint cure. I’m one of those guys who likes to dress up an ARF with small finishing touches rather than just tossing it together. They look better and it satisfies part of the building bug when there isn’t time to build from kit or scratch.
Will gladly answer any questions.
ID:	1013380   Click image for larger version
ID:	1013381   Click image for larger version
ID:	1013382   Click image for larger version
ID:	1013383   Click image for larger version
Dick T. is offline
Old 08-18-2008, 12:54 PM
jbarnes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wallace Gear for WM J-3 Cub ARF….
Dick, thanks for the update. I'm also ordering one of these WM Clipped Wing Cubs and want to get this gear. Didn't realize it took so long. Figured he had them already made up and shipped it ASAP. I'll be ordering mine this week. Thanks, Jerry.
jbarnes is offline
Old 08-18-2008, 12:55 PM
jbarnes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jbarnes is offline
Old 08-18-2008, 01:16 PM
Dick T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think he produces them in small batches so you might get one right away. My order landed in between.
Dick T. is offline
Old 09-05-2008, 06:13 PM
wiz310
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
took me three months to get a reply for information. I had the $$$ ready when I first emailed and was all keen to go, but gave up eventually. I suppose I was a little hesitant in parting with the $$ after waiting three months for an email............ I was wondering how long it would take to actually get the gear.
wiz310 is offline
Old 09-07-2008, 11:23 AM
ROGER RUSSELL
ROGER RUSSELL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I too have his gear on my WM 1/3rd CUB and also had to wait on delivery, communication etc.
Sent money and measurments in and still took a while.
However, very much worth the wait, nice looking and functional.
They got to me just in time as the stock gear started to give way and was being held together with small hose clamps.
Painted mine gloss black and then covered in yellow.
Only other mod I made is I added some more bolts to the mounting to the fuse.
PS:
Do you have you gear so they are a little spungee or are they pretty solid on landing/taxing?
I use small bungee chords wrapped around the hooks a couple times. I cut the metal wire off and use the hook on the chords.
Roger
ROGER RUSSELL is offline
Old 09-07-2008, 08:12 PM
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ROGER RUSSELL
My recommendation is to have it "sprung" more stiffly than you think is necessary.You should barely be able to manually move the gear legs against the bungee's tension. I have them that tight on my 1/5 scale L-4, but you can still see them deflect on touchdown. If they are too soft, and you have a harder than usual touchdown, it can bottom out the gear and bend the "V" strut (ask me how I know[X(] ) if it contacts the ground.
khodges is offline
Old 09-08-2008, 08:15 AM
jbarnes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You guys had me worried about the Wallace gear turnaround. I ordered it two weeks ago and got it 9 days later. I'm getting the Super Cub from WM and painting mine gloss white. Still waiting on my DL100 though.
jbarnes is offline
Old 04-11-2009, 03:59 AM
SON OF PALEFACE
SON OF PALEFACE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wallace is very ill and wont be making any more
SON OF PALEFACE is offline
Old 05-03-2012, 09:43 PM
andretorres89
andretorres89's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The web link that everyone puts out for piperj3gear.com is always wrong. Is there an alternative that anyone else knows?
I'm loosing my patience trying to find someone that makes these gears other than robart.
Any help would be great!
regards,
-Andre
andretorres89 is offline
Old 05-04-2012, 09:28 AM
Dick T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: andretorres89
regards,
-Andre
At one time there was the ad shown below that featured the original Wallace gear's new manufacturer. As near as I can tell, cubnuts is still an active RCU member. Might try sending an email.
http://www.rcuniverse.com/market/item.cfm?itemId=587543
Dick T. is offline
Old 05-04-2012, 03:18 PM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the Robart gear and I really like it , in fact I have4 sets of Robart gear , I have 2 1/3 Cubs , a 1/4 scale cub , and a 1/5 scale cub ... Why dont you like the Robart gear? Have you had trouble with it ?
bikerbc is offline
Old 05-04-2012, 07:30 PM
gordon_mcln
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cublandinggear.com took over for william wallace......
Gordon
gordon_mcln is offline
Old 05-04-2012, 07:58 PM
cjtyped
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have dealt with this company several times, and have never been disappointed. cublandinggear.com has even at times called me personally to make sure I would get what I wanted. I have even used their gear on a Tiger Moth by turning the gear 180*. I highly recommend this company. Cheaper than Robart and high customer satisfaction goals.
cjtyped is offline
Reply
Display Modes
