Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Pacific Aeromodels 97" GEE BEE Y Gen II ARF
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 09-21-2010, 11:31 PM
  #51
jp928
Default RE: Pacific Aeromodels 97
Finally got mine in the air...With engine box as far back as possible, 6V 1700mah battery behind wing saddle, 10AH Nimh ignition battery under cockpit, needed...35gm (1.5Oz) of lead on the tail - much better than I had hoped. Based on advice from another here who has EXACTLY the same set up, running a 21x8 prop, 20% nitro, 18% oil, when all cylinders are up, seeing 7200rpm. Balanced at 5-1/4"from LE. first flight - leapt off the ground and went up like an elevator - lots of down trim needed! No other trims needed touching. Throws all pretty much as per book, using the 'Normal' values. Motor has all the grunt needed - to me, it looked very scale, similar speed to the 85" version I have with a Moki 210, 22x8 prop.
Flys very nicely, just like the smaller one - low roll rate, but otherwise reponds very nicely to all controls, small amount of down inverted, so CG is good, and does a normal final approach, not really slowing as much as you would think for a radial cowl. All in alla very nice model, well behaved . Sadly on second flight I had too high an idle, it ran on a bit, dug in a wheel and psuhed the struct through the wing. No other damage, so it will fix fine. Found one of the oleo retaining screws coming loose, so these should be removed and re-installed with loctite. IIRC total weight was 10kg, or 22lbs on bathroom scales - had to get it inpsected under heavy model rules - over 7kg.
jp
Old 09-22-2010, 11:46 AM
  #52
Mr DJ
Hey Gents,
I didn’t realize that I had written in this thread two years ago. Well, I too just recently flew mine for the first time. The first flight lasted 20 seconds as my DA 85 cut off right after take off. The second flight lasted maybe 30 seconds as the same freakin’ thing happened. This time I landed way, way down the field into some tall grass and broke of one of the main gear. Got her all fixed up and ready for flight #3 but it didn’t happen because I couldn’t get my engine to cooperate. The deal is my engine is sucking in air big time from the tank. That’s ‘cause my tygon line is large; larger than the brass tubing. I use that line on my turbines. I just ordered some 1/8 size tygon which will give me an air tight fit. Hope to have some video for my third but first flight.
My engine is the DA-85 with a 28x10 twin blade but changed it on the second flight to a 26x10 3 blade. I have smoke on mine also.
Mr DJ
Old 09-22-2010, 12:17 PM
  #53
Ed
Over size Tygon gets a lot of people in trouble. 1/8 th ID is all that you will ever need. Sorry to see so many non-scale colors being used, but I guess that's a personal choice thing. Mine uses a Cunningham modified G-62.
Old 01-27-2015, 06:34 PM
  #54
hossinarizona
My Feedback: (22)
hossinarizona's Avatar
Anyone know where to start as far as the C.G. goes, I have hearc around 5 1/4" from the leading edge? Any additional information would be greatly appreciated.
Mike
Old 01-27-2015, 07:22 PM
  #55
redball8
My Feedback: (128)
redball8's Avatar
My instructions (the Happy Models knock-off of the 97" GBY) gave CG at 143 mm (5-5/8"), but after the first few flights I moved it forward (more nose heavy). 5-1/4" sounds about right.
Old 01-27-2015, 08:06 PM
  #56
Bob Zar
I have the instruction book, will post CG info tomorrow
Old 01-28-2015, 07:06 AM
  #57
pacoflyer
My Feedback: (23)
If anyone knows where I might find an oleo strut setup for the smaller,82" version I would appreciated it.
paul
Old 01-28-2015, 08:47 AM
  #58
CARS II
My Feedback: (7)
CARS II's Avatar
Paco
I would check with Maxford USA, they are base in the LA area and are now selling the 27% Gee Bee Y.
Old 01-28-2015, 08:50 AM
  #59
CARS II
My Feedback: (7)
CARS II's Avatar
Mine is flying perfect with the CG that I have, I will run to the storage today to get it off the side of the airplane ( I always mark the CG on all my airplanes just in case I need it later )
Old 01-28-2015, 10:23 AM
  #60
Bob Zar
According to factory manual the CG is 5 1/4" from the leading edge��
Old 01-28-2015, 10:25 AM
  #61
Bob Zar
Default Cg
The CG is 5 1/4 from the leading edge per the manual!
Old 01-28-2015, 02:48 PM
  #62
hossinarizona
My Feedback: (22)
Thanks for all the information on the C.G. issue, I will maiden it Friday, should be fun!
Old 01-28-2015, 03:47 PM
  #63
Bob Zar
Manage the throttle on landing ,there's a lot of drag due to the large cowl...Its a great flier.I am using a Brison 3.2😄😄
Old 01-28-2015, 04:32 PM
  #64
pacoflyer
My Feedback: (23)
Thanks Cars II
Old 01-28-2015, 06:12 PM
  #65
CARS II
My Feedback: (7)
CARS II's Avatar
I have only flown mine like 20 times, it came from a good friend not to long ago, it's all dialed in now and it is flying really good, it's a V1, a one piece wing ( very strong ) the only thing I'm having problems with is that on touch down it bounces to much, I read some here that reflex on the ailerons was used to suppress the bouncing, anyone care to comment on this?
Old 01-28-2015, 06:33 PM
  #66
CARS II
My Feedback: (7)
CARS II's Avatar
https://m.youtube.com/playlist?list=...lD_lIenXoVQAyN
Here is mine, next time I will have someone with the camera so that I can fly it.
Old 01-28-2015, 07:26 PM
  #67
CARS II
My Feedback: (7)
CARS II's Avatar
https://m.youtube.com/watch?v=a6fF9iMmmLI
For those guys with the V2, have you experienced something like on this video?
Old 02-01-2015, 09:25 AM
  #68
Bob Zar
How was the maiden??
Old 03-09-2015, 08:16 AM
  #69
Richard Wacks
I have a DLE 60 Twin that I think would work great in the Gee Bee. Could anyone tell me the I.D. of the cowl please? It would be great if it would fit inside!!!
Old 03-09-2015, 01:07 PM
  #70
CARS II
My Feedback: (7)
CARS II's Avatar
I have a BME 61 twin in mine and it fits just fine.
Old 03-09-2015, 03:07 PM
  #71
Bob Zar
My cowl is mounted I measured approximately twelve and a quarter to one-halfi inches I would expect your motor to fit����
Old 03-09-2015, 04:52 PM
  #72
Richard Wacks
S W E E T!!!!!! Now to find one! I think that I can still get one from Maxford. I always seem to find out about the great ones after the moment!! Thanks for the info!!!!
Old 03-09-2015, 05:29 PM
  #73
Bob Zar
You will love it! Looks beautiful in the air 
Old 03-09-2015, 05:31 PM
  #74
Bob Zar
Check out my gallery for pics!!
Old 03-10-2015, 01:46 AM
  #75
Richard Wacks
Whoa!!! You have some beautiful birds there!!! Incredible detail work as well!!! I hope that I can get the black and yellow scheme as well. I do like the red and white though.... could put a Texaco logo on her.... Thanks again for the info!!!
