Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Bob Nelitz 1/3 Scale J-3 Short Kit build
Reply
Old 05-31-2012, 02:48 PM
  #276
Leadtrumpet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bob Nelitz 1/3 Scale J-3 Short Kit build
Thanks I'll look them up tonight. I'm doing a full interior after a full scale PA-18A that belongs to a friend of mine. It is my first real "scale" build and I want to get the belts right!
Leadtrumpet is offline
Old 11-12-2012, 02:39 AM
  #277
claudbosc
claudbosc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello guys.
I have some difficulty finding some pieces of wood for my piper.
Can you tell me where to find these woods with these measures?
5/16 "X 1-1/4"
I need to build the wing.
I searched from National Balsa but I can not find them.
I ask for help because here in Italy we do not have these measures.
Thank you for your help.
claudbosc is offline
Old 11-12-2012, 02:41 AM
  #278
claudbosc
claudbosc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And I ask you something else:
In your opinion how many meters do I need wood in sizes 3/8 spruce dowel to complete the airplane?
Old 11-12-2012, 05:47 AM
  #279
misterbill
misterbill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Claud,
Cut all my wood to size on my Proxxon mini table saw. So I could make it exactly the size I needed. But 5/16" is around 9mm, and 1 1/4" is around 32mm if that helps.
I didn't use spruce for the dowels, couldn't find any, but I just used regular hardware store hardwood dowels. 18mm or so should do you if that size is available where you are.
Mike
misterbill is offline
Old 11-12-2012, 10:35 AM
  #280
Donairplane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bill,
What was the finished weight of your cub?
Beautiful job onyour cub!!
Will finish mine after our move to Arizona.
Don
Donairplane is offline
Old 11-12-2012, 10:38 AM
  #281
misterbill
misterbill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Don - don't exactly remember - it was a while back when I weighed the bits for the cg, but it was in the early 30lb range.
Thanks for the kind words.
Mike
Old 11-13-2012, 02:19 AM
  #282
claudbosc
claudbosc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello and thanks for the reply.
Since I am only plywood 8 or 10 mm thick.
To get them in wood joinery I should go in and have them cut to size but it would cost too much.
According to you, you can also use the plywood 8 mm?
Old 11-13-2012, 04:26 AM
  #283
misterbill
misterbill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
5/16 is actually 7.9mm so 8 mm should be perfect.
Google search for an inch to metric converter - it will help you. Here's one you could try
http://www.easysurf.cc/fracton.htm
Mike
Old 11-14-2012, 01:03 AM
  #284
claudbosc
claudbosc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: misterbill
Mike
Ok I will use the one from 8 mm.
But the plywood is okay or should I use hardwood?
Old 11-14-2012, 03:04 AM
  #285
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I assume the wood is for the main spar, that being said, plywood is not the best choice. Spruce or basswood would be the wood of choice. When you cut a strip of plywood for use on a spar, only half of the fibers are in line with the bending stress, the fibers that are 90 degrees from the bending stress add little to the strength. I would image popular wood is available in Italy? I thought that iswhere our lite ply originated, Italian Bending Plywood? I would use popular if basswood or spruce is not available.
Tony Hallo is offline
Old 11-15-2012, 02:44 AM
  #286
dadragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can go to your local welding supply store get a card with the convertions on it.it has fractions to metric.
dadragon is offline
Old 11-22-2012, 11:13 AM
  #287
claudbosc
claudbosc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ask for help.
Is there anyone of you who can get me the spars for the wings?
There are 4 pieces of spruce but here in Italy nobody has the time and desire to cut!
I'll pay the labor and shipping ...
Old 11-22-2012, 10:48 PM
  #288
gordon_mcln
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Claude,
Call Aircraft Spruce or order online....They can supply any size spruce you need. Another option is Wicks Aircraft Supply in Canada.
Gordon
gordon_mcln is offline
Old 11-26-2012, 07:38 PM
  #289
dadragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used spruce on a few planes now I go to the local Lowes or HomeDepot and get a couple of 8 or 10' peices poplar,just as sturdy as spruce and alot cheaper as I do ALL myown cutting.
dadragon is offline
Old 12-22-2012, 06:16 PM
  #290
crashman1432
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys. Love this thread. I purchase a used Nelitz cub some time ago. (Thought that it was a BUSA Cub). Lovely plane but has seen much wear and abuse. I am trying to rework it some and bring it back to a better state. Can someone post some pictures or details about how the wing secures to the fuselage. Not the strut attachments but the root rib connections. Particularly how are the hardwood spars finished off to be able to connect to the tubular cage. Mine has like a metal cap strip molded around the end of the spar. It is really buggered up and leaves a lot of slop in the fit. The rear connection is a dowel with a brass tube over it that slips inside the metal tubing. A hole is drilled into it and a wire slips through it to secure inside the tubing. Any pictures or help would be greatly appreciated. If I can get her spiffed up a bit I plan to put her on floats and fly her often at our local lake. Thanks for your help.
crashman1432 is offline
Old 01-28-2013, 03:49 PM
  #291
garypace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi I just received my cowling from fiberglass s. and started working on it and I noticed it was over a half inch wider on one side so I e mailed them and told them a bout the problem and sent some pictures , and this is what he said. [[ I can't tell what you are referring to. The cowl is what it is, if it's not
good enough for you, then you'll need to get it from someone else ]]
garypace is offline
Old 01-28-2013, 03:57 PM
  #292
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Post a photo of the cowl, Iam having trouble understanding your problem.
Old 01-28-2013, 04:05 PM
  #293
garypace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its over a half inch rounder one one side Itry to post picture for you
garypace is offline
Old 02-01-2013, 12:34 PM
  #294
bh307
bh307's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rare find in local hobby shop 1/3 scale Bob nelitz cub in pretty good shape , Had to have it now in my garge was not cheap but its my, builder did good job , now much work to get it in the air.
ID:	1846836   Click image for larger version
ID:	1846837   Click image for larger version
bh307 is offline
Old 02-01-2013, 12:37 PM
  #295
bh307
bh307's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more
ID:	1846839   Click image for larger version
ID:	1846840   Click image for larger version
bh307 is offline
Old 02-01-2013, 12:38 PM
  #296
bh307
bh307's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more
ID:	1846842   Click image for larger version
ID:	1846843   Click image for larger version
bh307 is offline
Old 02-01-2013, 01:17 PM
  #297
Donairplane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bh307,
Is Alex Guzman still cutting short kits for the cub?
Old 02-01-2013, 05:57 PM
  #298
bh307
bh307's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes I thank so
bh307 is offline
Old 02-04-2013, 04:29 PM
  #299
garypace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys I just started working on my cub cowling and just finshed cuting the rivots and would like to do panel lines on it and could use your thoughts on how to do them.
garypace is offline
Old 02-04-2013, 04:52 PM
  #300
bh307
bh307's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pictures
ID:	1848131   Click image for larger version
ID:	1848132   Click image for larger version
ID:	1848133   Click image for larger version
bh307 is offline
Reply
Display Modes
