Bob Nelitz 1/3 Scale J-3 Short Kit build
#355
Has anyone had a problem with attaching wing to fuselage and trying to access the screws to bolt the wing to the fuse? I built the wing and the metal tube frame that joins the wings together and fits very well but I foresee a problem with trying to get the screws from the front due to the windshield in place.
#356
Plans on DXF or DWG
Hello everybody.
I wanted to ask you if anyone has DXF or DWG Plans.
Kit Cutters unfortunately has closed and I can not find anyone who can cut the pieces.
#361
Landing gear, metal tube cabin structure, metal tube square for mounting the gear to,
Rcaiir.com
__________________
Epoxy Glass kits, Short Kits, Laser cut wood kits ,Fiberglass parts and much more.. Proudly made in the U.S.A. rcaiir.com
email: [email protected]
Rcaiir.com
__________________
#364
33% Cub kit is $650.00
Metal cabin frame is $220.00
Landing gear frame in the fuse the the gear mounts to is $65.00
landing gear is $205.00
Optional Fiberglass wheel pants are $36.00
Optional wood & fiberglass Dummy motor kit is $49.00
Optional Blisters the cover the pushrod exits on the wings pair are $18.00
#369
Ok got my covering ,pinking tape, POly Tak cement, POly Brush and other stuff today. I will get the Poly Spray and the Paint (Poly Tone) later because Chip likes to shake and freshly mixed all the paints before they leave .I will not need them for some time. Anyways I when with the polyfiber system because if your going to build a scale Cub then you need to use the system they use on the full size. Chip at stits.com([email protected] ) Can hook you up with everything you need to do the Cub Scale. Here is the list of what you will need to do the 1/3 scale Bob Nelitz J-3 Cub.
You will need 7 yards of fabric, a pint of POly Tak cement to attach it, 4 quarts of POly Brush to fill the weave and apply the finishing tapes, 3 quarts of Poly Spray to make the aircraft opaque so you don't see through it, and 3 quarts of White Poly Tone 4 quarts of Yellow Poly Tone and finishing tapes.
Billy
Billy
Steve (12-22-2021)
