If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 201 to 225 of 354
  1. #201
    misterbill's Avatar
    Join Date
    Oct 2003
    Cobourg, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Bob Nelitz 1/3 Scale J-3 Short Kit build
    Check out post #49 on this thread (Page 2?) for Billy's aileron method, or the other Nelitz Cub thread for more info, I believe from FrequentFlyer.
    The other thread is here http://www.rcuniverse.com/forum/m_89..._1/key_/tm.htm
    I think Dubro are the only big Cub wheel people.
    Mike
    1/4 DH82a Tiger Moth
  2. #202
    Join Date
    Aug 2004
    Prairieville, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Guys,
    I can't figure out how the wing aileron servos are attached have two ways it could be.
    1. permanently glued, if so how are they changed out.
    2. the mount is fitted to stop even with the outer wing rib and is held in place by the fuselalge rib.
    Any other ideas?
    Wayne
  3. #203
    misterbill's Avatar
    Join Date
    Oct 2003
    Cobourg, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wayne - go more modern.
    The servo's at the wing root will cause you to have to use bell cranks if you follow the now, pretty old, engineering on Bob's plans.
    Rather situate the ailerons outboard where the aileron horns are & use servo extension leads.
    The ribs are so large, I have mounted mine directly in the rib - puts the servo arm in direct line with the horn - with an access hatch in the lower wing surface for maintenance.
    Hope that helps,
    Mike
  4. #204
    Join Date
    Aug 2004
    Prairieville, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Misterbill
    In the attached picture I have a question about the x-section note in the cabin area.
    The members I have circled in red should they be cut down the thickness of the plywood doubler as the note shows but the upper and lower members circled blue should not be cut.
    Or are they all cut or none cut, some times it appears they are all cut, then again it appears none are cut.
    If you recall, please let me know and thanks in advance.
    Hopefully the picture appears
    Wayne
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #205
    misterbill's Avatar
    Join Date
    Oct 2003
    Cobourg, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Wayne - yes they all are. Flatten them on one side by the thickness of the doubler.
    The plans as you have seen indicate just a bevel at the bottom longeron but it really doesn't affect anything appearance-wise, and flattening off the dowel makes for a much better joint.
    The top one I flattened as well, but rounded the top of the ply doubler on the inside of the cockpit to match the dowel shape on the outside - covered you wouldn't know its not a piece of tubing. Hope that's understandable!
    Good luck with the build.
    Cheers,
    Mike
  6. #206
    airplanegeek's Avatar
    Join Date
    Mar 2005
    bird in hand, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    is the short kit still available? and if so how much?
  7. #207
    Join Date
    Aug 2004
    Prairieville, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Check Post #76
    $190 plus packing and shipping .The dummy engine will cost $30 to be cut plus packing and shipping
    Please contact Alex Guzman at:
    by email: aguzman@myacc.net
    Bought one 3 or 4 months ago, good wood and nice job.
    Wayne
  8. #208
    Join Date
    Mar 2005
    bird in hand, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thank you
  9. #209
    Join Date
    Mar 2005
    bird in hand, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    any suggestions for a gas four stroke for this bird
  10. #210
    Join Date
    Mar 2005
    Easton, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm using the twin Saito 57cc for mine.
    Fleet Brotherhood #18
  11. #211
    Join Date
    Mar 2005
    bird in hand, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    are there any moki 50cc singles out there? I think the combo would work nice.
  12. #212
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guysI have been out awhile,But im back. I had a move,-lost all info on my computer-and built a busa 1/3rd sopwith pup,-NOW BACK TO THIS BEAUTIFULL PLANE!! I will be on till completion this go around. I have one and 3/4s wings done along with the rudder and will post pics tomorrow. I am a little confused about the aileron build. I will go back in the threads and study again. I am looling for all the bits of metal guys had to offer for the landing gear and what ever else I need. I have the fiberglass cowl. All you guys have been AWESOME the last time I was on. I will be of coarse asking MANY questions again. This has been one of the VERY best threads I have ever been on!! Any advice or help would be DEEPLY appreciated!! ANYONE have a landing gear kit so to speak of?? I have a busa windsheild if it will work and how about a seat,dash,or anything else-MISTERBILL?????? YOUR THE MAN! I have bear decals along with the piper decals-Need the rest,-Lighting bolts and such!! Frank Vitale!
  13. #213
    Join Date
    Jun 2002
    Sheridan, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    will you finish mine thanks frank
  14. #214
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Frank, If your serious-mail me!! rotorboy2.4gh17@yahoo.com Frank!
  15. #215
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is about where I am at! I built some jigs for all the hard wood ends that will hold three peices at a time-VERY handy! Sorry for the last pic of Sopwith pup stuff!
ID:	1697478   Click image for larger version.
ID:	1697479   Click image for larger version.
ID:	1697480   Click image for larger version.
ID:	1697481   Click image for larger version.
ID:	1697483   Click image for larger version.
ID:	1697484   Click image for larger version.
  16. #216
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    On the last post-my Crappy pics made my spars looked tweekedThey ARE NOT!! AND DON, Thanks for the info. I am just a little tight right now. But I WILL COME TO YOU, as your work looks OUTSTANDING!!THANKS!! Frank Vitale!
ID:	1697489   Click image for larger version.
ID:	1697490   Click image for larger version.
  17. #217
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone completed their cub?? any Videos-How bout you Mr. Bill? Frank Vitale-Im gonna catch up QUICK!!! COME ON NOW!!
  18. #218
    Join Date
    Jun 2002
    Sheridan, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sweet, my plane would be nice in your hands, where in mo are you at ? thanks fank
  19. #219
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey FrankI am in Saint Louis!!Frank V.
  20. #220
    misterbill's Avatar
    Join Date
    Oct 2003
    Cobourg, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not quite done, but nearly.
    Here are some pix to keep you guys going - keep at it, it's really worthwhile.
    They're basically interior shots as that's what I'm finishing up right now.
    It's taken a while but it is coming together well, and hopefully in the not too distant future it will be capable of emerging from my basement workshop.
    Don't have enough room in there for an overall assembly (or picture!), so that will have to wait till it's hangered in the garage.
    Basically I just have the dummy Continental to finish dealing with (the cylinders are already done), the cowl to paint and a few under wing bits, and then 'roll on flying season'!
    Cheers,
    Mike
ID:	1697552   Click image for larger version.
ID:	1697553   Click image for larger version.
ID:	1697554   Click image for larger version.
ID:	1697555   Click image for larger version.
  21. #221
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike-TRULY AMAZING!! As I stated long ago, your build of this MARVELOUS plane is the standard I am shooting for. Where can a guy get some interior bits from-or just scratch it? Thanks for the pics mike!
  22. #222
    misterbill's Avatar
    Join Date
    Oct 2003
    Cobourg, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aah ...the good old fashioned hard way.....DIY!
    Not that hard, just takes time. And more time...
    I'm doing the panel right now, then the windscreen goes in.
    I'll post some more pix as it happens, but don't hold your breath, there's that other sidetrack looming at this time of year...
    Cheers,
    Mike
  23. #223
    Join Date
    Mar 2005
    bird in hand, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I thought I was looking at the full scale! WOW good job. Keep the pictures coming !
  24. #224
    Join Date
    Dec 2008
    pine bluffs, WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I built the nelitz cub about 4 yrs ago,all the fuse was alum tubeing using metalweld apoxy and after 51 flights off land and with floats its still holding together well.the only part of the wing I used alum was the tips,they roll rite out then a little tweeking and bam wing tip.your build looks realy good too.
    keep your powder dry and pray the creeks dont rise.
  25. #225
    Join Date
    Apr 2009
    st. louis, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And I thought I was doing good with the hard wood jigs I madeI remain humbled.[&o]-Frank!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
