throttle & choke connections
My Feedback: (12)
CA
I,m reading you guys are using ball links for choke & throttle connections. I need to know how you make them fit. Are there adapters that make the choke & throttle longer so the ball link will fit. If I grind off the choke lever & take out the pin, is that a threaded shaft so I could put a screw in like the throttle?? Kinda confused......Thanks guys
RE: throttle & choke connections
Heres a pretty good picture of what I did. I used some brass that was laying around the shop and shaped it like a control arm then soldered it to a wheel collar that fit the shaft. Then went back and redrilled the wheel collar. Took about 20 minutes in the shop.
Edwin
Hmm - not letting me post the picture. One more time.
Edwin
