Harris Smoke Pump Issue
CO
I think I have a problem with my pump. I had been using it for the last month or so and it was performing well, but I wanted to change the setup in the radio yesterday. Wanted to change switches. In doing that, I can't get the pump to respond to the radio anymore after playing with it for a while. When I turn it on it just produces ascending beeps, one after another about 1 second intervals and won't do anything else no matter what I do. I even set the pump back up the original way it was working before and still doesn't work. Anyone have any ideas or seen this happen?
It seems like the ESC for the pump may have taken a dump. It appears to be just a brushless motor with an ESC. Wonder if I could put a new ESC on it?
NY
RE: Harris Smoke Pump Issue
ORIGINAL: hanko
I guess i owuld try plugging the pump directly into the battery and see what happens. Youll know if its the pump or radio set up
