Basic Smoke Pump
hello,
I buy this: http://www3.towerhobbies.com/cgi-bin...&I=LXHS73&P=ML http://www.hobbycity.com/hobbyking/s...idProduct=9090 all on the lipo 1000MAH 2S the esc does not beep? I do not understand why? help me please, thank you |
RE: Basic Smoke Pump
I don't really follow why you have the turngy esc in the picture? Anyway, I'd hook the lipo straight to the tme smoke pump.
is there a jumper for nicad or lipo in the ESC that needs switched? I ran into that once.
If I understand, you are using the ESC as a switch?
I believe the ESC connects to channel #3 to work correctly, however, please confirm this with others. The pump you choose works very well, and can be activated by a simple on-off type switch with servo if you wish. |
