RE: Buiding pics Waco YMF-5 Barth Modellbau
1 Attachment(s)
Yes I now wat you mean I think it is for major adjust on the real Waco , i have also seen it on a lot of pictures.
I have made the stab only removable (see earlier pictures), i think if you made the first sadle adjustable in height you are close to the solution. Cesar. |
1 Attachment(s)
The two fairings on the fuse/wing are put in place and the folie is covering on the fuse.
Cesar |
I've seen this project in real, and it's going to be a very nice looking plane[8D]
Keep up the good work Ruud! Greetz. |
1 Attachment(s)
Thank you Alex, i will try to keep the spirit up.
I have finished the panels on the fuse. i think that after the paintjob it looks better, the screws are now to much visible. Cesar. |
Hi Cesar,
Compliment, your plane looks "GREAT"!!![sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif] Which Covering material do you use? And is it easy to handle? In my opinion the screwheads will get more in the background after painting, same mind like you! What kind of paint are you planing to use,1K or 2K ? I have to wait two weeks more, until I will recieve my kit, so told me Peter Barth[:o] I´ve gived up my plans, to make the stab pretendable, because of reasons of stability. What´s a Servo is it, in the rear of the cockpit? Regards Bernie |
ORIGINAL: SoCalSal I used a HiTec 5955 digital that puts out 333oz @ 6 volts. .................. Cost is about $96 U.S. each. If you have any questions , please let me know and I will try to help. Steve I will use 4 Hitec HS-645MG, one for every aileron. Bernie |
Well one servo on each will be very good. I'm sorry that the 5955's cost so much in Germany. That just seems unfair to you over in Germany to have to pay almost two times the price for the same thing. there may be a way to order them here in the States and have them shipped to your home for far less than buying them from a German hobby supplier.
Steve |
ORIGINAL: BigBoy99 Which Covering material do you use? And is it easy to handle? In my opinion the screwheads will get more in the background after painting, same mind like you! What kind of paint are you planing to use,1K or 2K ? I have to wait two weeks more, until I will recieve my kit, so told me Peter Barth[:o] I´ve gived up my plans, to make the stab pretendable, because of reasons of stability. What´s a Servo is it, in the rear of the cockpit? Regards Bernie The covering material is Oratex it is a polyester fabric and it is verry easy to aply. Look at http://www.oracover.de/xml/frames.xm...ml?node_id=273 I wil use 1K paint, that's a litle bit easyer for me to use. The color i wil be use is RAL 9001. I have not the possibility to spray the the paint so iI wil be use a felt roller. I hope for you that you not have to waite to long for your Waco, let me now when you recieved it. The servo's I wil be used are the 645MG and the 755HB for rudder. You say"not pretendable" okee but for transport it is better to make it removable I think. Regards, Cesar. |
Hi Ruud,
thanks for your quick reply. Oratex is also the material I want to do the covering, I see, I had a good choice ;) I think. the HS 755HB is a little bit too small for the rudder and elevator. Elevator is the most important rudder in the model, and if you loose the elevator, you loose the model!!!! I would recommend the HS 5745, for the elevator and the rudder. It has a power of nearly 19 Kg!!! But this is only my opinion. If anybody else think otherwise.....post! Or the HS 5955´s, but they are more expansive I prefer a color, something between RAL 1018 and RAL 1023, I´m a yellow fan. Chuck sent me the the dwg files for the decals, thanks to him...good fellow[sm=wink_smile.gif] Thanks to him! Now I wish you for the rest of the weekend best success for your work[sm=wink_smile.gif] Bernie |
1 Attachment(s)
Bernie, You say you like yellow?? Here is my Yellow Waco.
Steve |
Hi Bernie
I wil work with 6 V on the servo's. the 755HB is than 13,2 kG. I wil use for the elevator two servo's, for each flap one servo that's a total of aprox. 21 kG. I dont no if you wil use two servo's on the elevator? Cesar. |
Hi Steve,
IT LOOK´S GREAT, compliment !!! [sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif] Is it you, on the photo? Yes, I like yellöw, but I prefer more Yellow with red :D @cesar Thats good, it´s a solution, if one servo failure, you have a second on the other flap. but in this case, I think so, it works like a little aileron and you have to steer against with the ailerons?[sm=confused.gif] Greeetz to both and all Bernie |
Hello Bernie, yes that is me in the photo.
1 Attachment(s)
I build in the elevator servo's and put the rudder and fairing in place.
Cesar. |
You are doing a very very good job on this project. Keep up the good work!!
Good job, Cesar!
I enjoy, to look to your pictures, they are very good, to plan the assemble in the mind. I´m still waiting for my kit. Don´t stop with the pictures here, it´s a great help for me. Regards Bernie |
1 Attachment(s)
The headrest is fixed to the fuse.
I am now busy with the cabane struts and the mounting of the upperwing center section, it is a precise work because it sets the angle off the upper wing. Cesar. |
Hi Cesar,
do yo know this link? It´s a report of building a YMF-5 from Barth, certainly in german, with a lot of pictures. http://www.rc-network.de/forum/showthread.php?t=36236 Your CD is ready and covered and will be sent tomorrow. Vriendelijke groeten, Bernie |
1 Attachment(s)
Thank you for the link Bernie, i have read and study it for 2 hours and it give me a lot of extra info.
I am now busy with the N struts. I have placed the fuse with the nose flat on the ground and put on the wings with the tubes. I have not so much room but this way gives a me a good way to maesure etc. The angle off the top wing centre section i have already checked and is set on -1 degree. |
Hi Cesar,
by heaven, it´s not easy, to built in a such small room a Waco 3m[sm=thumbs_up.gif] Where are you planing the mounting points of fly-wires, outside or inside of the wings/fuse. Do you use the wires from Gautschi? www.bredavik.se/flyingwire Regards Bernie |
1 Attachment(s)
Hey guys!
Just finished my 40% Waco powered with a RCS 400cc radial spining a 40-18 prop. Enjoy the pictures. Dany |
ORIGINAL: GENESIS Hey guys! Just finished my 40% Waco powered with a RCS 400cc radial spining a 40-18 prop. Enjoy the pictures. Dany Would love to have one but the size, weight and the COST is so far out of the average modlers range it will remain a dream to 99% of most of us average Joe's |
Hy Dany,
great finish, congratulations! I love this plane(and my woman)! I´m missing too the flying wires, same first mind like Steve........it´snot so easy to mount them with gloves, ha ha ha :D Good job Regards Bernie |
ORIGINAL: BigBoy99 Where are you planing the mounting points of fly-wires, outside or inside of the wings/fuse. Do you use the wires from Gautschi? www.bredavik.se/flyingwire How, i dont now yet but with a kind of a clip and M3 kwiklinks were I first put out the pin. When i am ready i will show you with some pictures. I known the wires that you named but it is a little bit expensive. I think the wire that came with the kit is a little bit to thin, i have one size thicker which i will use. And Dany, nice pictures off your new Waco, with that engine it will be a real performer....verry nice. Cesar. |
Hi Ruud,
what´s abot news of your Waco? I´m still waiting for my kit, and this in Germany, the home country of the manufactor......crazy!!!! In one week I will cancel my order, so I told to Peter Barth. Perhaps I will build a Boeing PT-17 Stearman 88"( 2,24m), but it´s not a kit.I bought onlyt the plan from Nick Ziroli. But it´sa lot of work, if you have to built every part by yourself. Here in Germany we say: The hope is dying at least.....I will wait for one week more. [&o][&o][&o] Regards Bernie If there is anyone in the USA, who knows how to ship a Kit from Genesis to Germany cheep, post!!!!!! |
