Convert Dyna-flite Butterfly
My Feedback: (56)
MS
I have a Dyna-flite Butterfly motor glider currently on an OS 20 glow engine. What size electric motor/speed control do I need to convert this to electric power? Her are the specs for the Butterfly:
SPECIFICATIONS
Wingspan: 99 in (2515 mm)
Wing Area: 916 in² (59 dm²)
Length: 48.5 in (1230 mm)
Wing Loading: 7.5 oz/ft² (23 g/dm²)
Weight: 50 oz (1415 g)
Requires
Engine: 2-stroke .15-.20 or 4-stroke .26 engine
Thanks in advance!
SPECIFICATIONS
Requires
Thanks in advance!
RE: Convert Dyna-flite Butterfly
Well if you run a MP .15 motor
http://www.hobbypartz.com/monsterpow...ess-motor.html
40 amp ESC
http://www.hobbypartz.com/volcano-40...oller-esc.html
3s 2200mah battery
http://www.hobbypartz.com/83p-2200mah-3s1p-111-30c.html
APC 12X6 prop.
This calculator says it will give about 65 ounces of thrust.
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz
40 amp ESC
3s 2200mah battery
APC 12X6 prop.
Buzz
