Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Hangar 9 Alpha. 40. Electric setup
Reply
Old 08-26-2011, 10:49 PM
SpshlD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hangar 9 Alpha. 40. Electric setup
SpshlD is offline
Old 08-28-2011, 07:20 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hangar 9 Alpha. 40. Electric setup
Going by just the title!
A .40 IC motor is roughly equivalent to 800W electric [cubic inches x 2000].....Choose a motor rated for ~900-1000W, and to keep amp draw down, use 4s-6s... motor Kv will need to be selected according to the pack you choose, and the size prop you need to use.
Here is one suited to 5s: http://2dogrc.com/product/dualsky-xm...t-900w-46-size
Dr Kiwi is offline
Old 02-03-2012, 11:28 PM
chuckk2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The E-Flite 25 works well for a trainer. A more powerful, heaver and larger motor will make the Alpha 40 behave more like a pattern A/C. Mounting the larger motor will require some work.
With the 25, you end up adding 6-8 Oz. of weight to the nose, or moving the wing back about an inch. The larger motors may eliminate the extra weights.
While you are at it, shim the nose gear bracket to the front. This gives more clearance for the control horn.
chuckk2 is offline
