Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Lanier RC Stinger II by Great Planes.
Reply
Old 08-30-2011, 01:11 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lanier RC Stinger II by Great Planes.
Ok,
Stayed with the standard servos Futaba S3004.
HobbyWing Platinum-60A Brushless ESC
Tacon Big Foot 46 Brushless Out Runner Motor (670KV)
3 blade MA 12x8 prop, waiting for a 12x8 Neodym
Zippy 4s 5000mah 20c
Plane flies very well, motor gets just slightly warm, ESC stays cool. I am using the built in BEC and seems to be fine. I tried this set up with a Rhino 5s 4900 20c with 13x6,12x8, and 12x10 props, seems to be a little heavy and starts to torque a little on take off.
I will get some pics posted.
Andy
AJsToyz is offline
Old 10-09-2011, 04:49 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Lanier RC Stinger II by Great Planes.
Nice info. How about those pics? Looking for motor install and battery tray.
TIA
Phil
rfan_1 is offline
Old 10-10-2011, 02:19 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to let you know I have flown this with the Tacon .46 but have the Great Planes 42-60-800 on it now (Rimfire .46) . It flies fine with the Tacon but is now getting over 7lbs of static thrust with a MA 12x8 3 blade pulling 66 amps WOT. The way the motor is mounted in the pic is almost perfect for firewall spacing using the nylon spacers. I used the GP mount just because I had it and it did not fit my Hobby King motor. The motor I found @ Hobby King is cheap but the set up getting the three blade prop, spinner, costs a little.
ID:	1672435   Click image for larger version
ID:	1672436   Click image for larger version
ID:	1672437   Click image for larger version
ID:	1672438   Click image for larger version
ID:	1672439   Click image for larger version
ID:	1672440   Click image for larger version
ID:	1672441   Click image for larger version
AJsToyz is offline
Old 10-10-2011, 03:08 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the pics. It looks like you have the battery over the CG, right? I'm guessing you used 2 1" nylon spacers also. How far is the spinner backplate from the front of the cowl? Pretty simple conversion. I wonder why GP didn't make it an option.
rfan_1 is offline
Old 10-10-2011, 03:26 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was pretty easy, they should have offered an electric conversion. Yes those are just 1"nylon spacers from the hardware store. I have them on a couple of planes now. The battery ends up in front of the cg, I will need to double check it after it's 100% finished. The spinner is about 3/32" from the cowl. I will have it out tomorrow and then have everything set. One thing though it's very tight on a large 6s lipo, not to mention it flies much better on a diet.
I'll post a picture in a day or two where the battery ends up and the cowl on. If I did another I might just make the battery tray longer.
Andy
AJsToyz is offline
Old 10-17-2011, 05:41 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a couple of pics showing the motor mockup and a recycled battery tray installed in my Stinger II build:
The distance from the firewall to the prop hub is exactly 4 1/2" using 1 3/4" of nylon spacers.
After finalizing the motor and cutting the excess bolt material, all that's left to do is the ESC, cowl, receiver, landing gear and CG/EPAs.
The plane is going to be way overpowered. It's gonna be a hoot!
rfan_1 is offline
Old 10-19-2011, 07:16 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plane all together now. CG is coming out nose heavy with a 4000 4s pushed all the way back to the receiver. This is without the spinner. Just might have to relocate the receiver or add some tail weight.
rfan_1 is offline
Old 10-20-2011, 11:43 AM
BlackPowder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys,
I'm doing this conversion also. I went with the E flite 46 for tne motor and E flite ESC 60 amp. I also cut out the tank floor and made a floor for the battery pack. Not shure which size prop to use yet. Mine balanced a little tail heavy but I had to order a new spinner, the one in the kit wobbles. So I will do a finale balance when it comes. Jim
ID:	1676872   Click image for larger version
ID:	1676873   Click image for larger version
BlackPowder is offline
Old 10-20-2011, 05:00 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got my cg sorted out. I'm using an e-flite 4s 4000 30c lipo and started out with an APC 13x10e prop. First run up pulled 63a @ 993 watts. That would be nice, but I'm going to stay within the motor's specs for WOT. I dropped down to a 13x4 and that was way too much of a pitch reduction as it only pulled 27 amps and 423 watts. I settled for the 13x10 and reduced the throttle travel to 65% and that pulled 53 amps and 831 watts. Perfect. I will get a 13x7 or 13x8 and return the throttle to 100% next time out. The maiden went very well. A few clicks of up trim was all that was needed. The plane ROG easily with no rudder needed. I set the throws per the manual and they're good for the first flight. Rolls are gentle, somewhat faster on high rates but not a blur by any means. Loops on high rates are nice and tight with no tendency to snap out. Speaking of snap, the high rate snap is excellent. Make sure the battery is well secured as mine shifted and I'm sure it was the snaps that did that. The plane will not stall. I got some altitude, shut the throttle down and fed in high rate elevator as it slowed down. All it did was drop the nose slightly and gently waffled the wings. It did not try to roll over. The plane lands like a pattern plane. Rock solid. It will come in a little hot, but slows down nicely using a longer glide path. I knocked out the blind nuts in the canopy and cut down the 2/56 throttle rod to make a simple latch, as opposed to using the screws every time. Small fuel tubing is what holds the rod in place. Here's some pics of the finalized setup:
rfan_1 is offline
Old 10-20-2011, 05:31 PM
BlackPowder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rfan 1,
Sounds like a very good flyer, I used to have the 120 size and it flew very well, so when this one came out I new that it would be a good flyer. Also I was going to try a 13 X 8 prop, and from your info I think it will work. Good job, thanks for the update. Jim
Old 11-02-2011, 05:11 AM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here an update to my previous post. I tried an APC 13x8E prop and the results were disappointing. I reset the throttle travel to 100% and the WOT output was only 41 amps and 653 watts. I went back to the 13x10 prop and reduced the throttle travel back to 65%. I think I'll try a 5S lipo.
rfan_1 is offline
Old 04-26-2012, 01:47 AM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just started a stinger conversion
cut out the fuel tank tray
epoxyed and screwed some plywood for battery
put a motor mount on
and glued on the tail
will be useing a G-force 46 600 kv motor
G-force 4000mah 4s 40c lipo
hobbiewing 80a esc
hobbywing 5a bec
power hd 1501mg servos
ID:	1755113   Click image for larger version
ID:	1755114   Click image for larger version
ID:	1755115   Click image for larger version
ID:	1755116   Click image for larger version
ID:	1755117   Click image for larger version
ID:	1755118   Click image for larger version
ID:	1755119   Click image for larger version
bhcnomo is offline
Old 04-26-2012, 06:57 AM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@bhcnomo: I was dissapointed with the plane's performance using 4S. I switched motors from the power 46 to the rimfire 46 and ran that on 5S with a 13x8 Xoar e-prop. It's a whole different plane now. The motor you're using is rated for 6S so you should consider going that route IMO. You're just not going to get the RPMs with the 4S. Have you fitted the cowl yet? When I tred the GP motor mount I couldn't get the motor back far enough and ended up going with nylon spacers instead.
rfan_1 is offline
Old 04-26-2012, 03:02 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rfan how did it fly on the 4s
my skills are not up to 3d yet
was going to get a bigger battery
did not fit the cowl yet did put it on to see if it would fit
its ok if the two halfs on the motor mount are all the way toghter
got to put the servos in and connect the control lines
to see how the cg is and move the motor in or out to fix
the power46 was in my GP shoesting useing two 3s connected in parallel
but two 3s will not fit in the stinger
ID:	1755361   Click image for larger version
ID:	1755362   Click image for larger version
bhcnomo is offline
Old 04-26-2012, 03:39 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you have them I series or parallel ? I can run the 800kv on 4s using a 3 blade 12/8 flies very well. I had the 670kv motor and would fly but not much power. HobbyKing has a couple heli motors that look promising but have not had a chance to try them. Might be able to fly with a smaller prop on a 3s lipo.
Andy
AJsToyz is offline
Old 04-26-2012, 03:48 PM
rfan_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane flew okay on 4S, but somewhat ho-hum as sport planes go. Consider this: At 4S using 14.8v nominal voltage, your 600kv motor will only be turning 8800 RPM, theoretically. Using 6S at 22.2 nominal voltage, that same motor will be running at 13320 RPM. Again, theoretically. Big difference. Now, fully charged the RPM jumps to 10080 for 4S or 15120 for 6S. On 6S the capacity/size of the lipo can be reduced. I'm currently building Stinger number 2 (rip Stinger number 1) and I have a 6S 3600 Turnigy that has plenty of room for CG adjustment.
rfan_1 is offline
Old 04-26-2012, 05:06 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the two 3s where connected in series
bhcnomo is offline
Old 04-28-2012, 01:19 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here some more build photos
that plywood plate makes the lg stronger
used it on my mini pulse and electro stick
ID:	1756061   Click image for larger version
ID:	1756062   Click image for larger version
ID:	1756063   Click image for larger version
ID:	1756064   Click image for larger version
ID:	1756065   Click image for larger version
ID:	1756066   Click image for larger version
bhcnomo is offline
Old 04-28-2012, 07:25 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is how i mounted the esc
ID:	1756179   Click image for larger version
ID:	1756180   Click image for larger version
ID:	1756181   Click image for larger version
ID:	1756182   Click image for larger version
ID:	1756183   Click image for larger version
bhcnomo is offline
Old 05-01-2012, 05:07 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cowl and prop is done
painted the lg plate white
bhcnomo is offline
Old 05-03-2012, 05:17 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is one way to lock the canopy down
took out the blind nuts
glued on some magnets
used two 10mm long bolts
ID:	1758366   Click image for larger version
ID:	1758367   Click image for larger version
bhcnomo is offline
Old 05-05-2012, 06:36 PM
bhcnomo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
video of the maiden flight
www.youtube.com/watch
bhcnomo is offline
Old 05-06-2012, 06:12 AM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just picked up a couple higher kv motors to try a little different set up, a 880kv and 1100 kv, we'll see how it works out.
AJsToyz is offline
Old 12-18-2012, 11:15 AM
dawhale
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just got a Stinger II. I was thinking of using a E-Flite Power 52 & 5S Lipo. Did any of you try the 5S Lipo with the .46 motor?
dawhale is offline
Old 12-18-2012, 11:53 AM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew a GP Stik with that set up and it flew fine. Depending on the mah you are going with the 5s might be the biggest battery that will fit the plane. A 6s 5000mah will not fit in the plane.
AJsToyz is offline
