Glow to Electric Conversions Discuss glow/gas conversion to electric here.
.40 Glow to Electric
Reply
Old 10-16-2011, 09:46 AM
craigm1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .40 Glow to Electric
I have a .35 to .40 size glow high wing airplane that I would like to convert to electric. Not sure exactly what model it is, I got it at a flea market without any gear. It's a 4 channel tail dragger, 50" wingspan, 39" fuse. Electric is new to me so I'd like a turnkey suggestion for converting to electric - speed control, motor, batteries, prop. I'm using an airtronics radio. Can anyone provide me with the components to convert?
Thanks in advance,
Craig
craigm1 is offline
Old 10-16-2011, 06:19 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: .40 Glow to Electric
Without knowing anything other then it is a 40ish sized high wing tail dragger, here.
ESC
http://www.hobbypartz.com/07e06-proton-60a.html
Motor
http://www.hobbypartz.com/96m604-big...520-770kv.html
Battery
Going with a 14X6 APC "E" prop should give you around 125 ounces of thrust or 780 watts. A slow easy flying trainer can get by with 100 watts a pound. But it will be a slow flying plane.
Buzz.
blvdbuzzard is offline
Old 10-17-2011, 04:33 AM
craigm1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buzz,
Thanks for the response. Looks like the battery link you posted is the same as the motor link. Can you re-post the link to the battery you suggest for this setup? Also, I didn't measure the clearance in the front - not sure if I can put a 14" prop on it. Can I put something smaller on it?
Craig
craigm1 is offline
Old 10-17-2011, 05:01 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DOH!!!!!!!!!!!!!
See what happens when you get going to fast
http://www.hobbypartz.com/83p-4000mah-4s1p-148-20c.html
http://www.hobbypartz.com/98p-25c-4000-4s1p.html
Buzz.
Old 10-17-2011, 05:31 PM
craigm1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buzz,
Thanks for the battery info - do you think that Tacon 32 motor will be strong enough? Also, is there a smaller prop I can go with - 14" might be too big for that plane.
Craig
craigm1 is offline
Old 10-20-2011, 05:46 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is the one problem with E power, they use bigger props. I had to make new gear when I did a e conversion on a 60 sized plane. I had to go from a 12 inch prop to a 16 inch prop. Had to make new gear that was 2 inches taller.
If you can find a 12X8 3 blade prop, it will give you about 7 pounds of thrust. So, how much does your plane weigh?
http://www.cermark.com/products/EMP-...12x8-prop.html
http://www.valuehobby.com/product_de...44&item_id=435
Buzz.
Old 10-22-2011, 11:49 AM
craigm1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane is a work in progress, there's no covering on it. The weight right now, with...servos, radio, main gear. Without...battery, no motor, no esc, no tail wheel, no prop...about 2.5 lbs. How much does the covering, power train weigh? Would that push it over 5 lbs?
Using webocalc, I'm coming up with 11x5.5 or 12x6 prop at 5 lbs. A 12" prop would be a little close to the ground.
craigm1 is offline
Old 10-29-2011, 05:39 PM
nute12
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just converted a 40 size heckler to electric. went from a .56 saito to a turnigy g-46 550 kv motor, 60 amp speed control and a 3300 4s lipo(40 c)
I am impressed, first 8 minutes it has more power than the saito by quite a bit. hovers at 1/2-2/3 power. pulls out of a hover great. rest of the flight ( to 12.5 minutes) is still very spirited but not like the first 8. throttle management just sport flying i could easily see this thing run 18-20 minutes. next batt will probably be a 4200 4s. I am also going to switch out the 14/8 for a 15/6 or 8 for a little more thrust. AUW is 4 pounds, 48" wing span and 41" long. motor batt and esc is 29 oz's
here is the battery, esc and motor i purchased for it. http://www.hobbyking.com/hobbyking/s...dProduct=19027
http://www.hobbyking.com/hobbyking/s...idProduct=2166
http://www.hobbyking.com/hobbyking/s...dProduct=15004
nute12 is offline
Old 12-01-2011, 05:19 AM
Marcio Senger
Marcio Senger's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fantastic plane nute12, exactly the kind i like the most!
Marcio Senger is offline
