Go Back  RCU Forums > Electric Aircraft Universe > Glow to Electric Conversions
Reload this Page >
Large scale warbirds, best ARF for electric conversion?
Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Old 11-11-2011, 05:51 PM
orthodoc
Default Large scale warbirds, best ARF for electric conversion?
Hey guys,
Hoping you can advise me on choosing next warbird project. Looking to add to my Top Flite 60 size P-47 and P-51 ARFs. Both were relatively easy to convert to electric with "hidden hatch" ready to be cut out from the fuse. I used Power 90 running on 8S on both and love em.
I would like to find very scale 60 size warbird ARF that either comes with hatch for batteries or easy to modify. Not too particular about model ( other than not thunderbolt or mustang). Considered new TF corsair but called them and told that no hidden hatch built into fuse anymore. The hangar 9 corsair doesn't come with flaps and doesn't seem as scale. Please advise - would love to tackle spitfire, warhawk, etc I could find the right ARF. Help!
Andrew
Old 11-12-2011, 06:03 AM
TLH101
My Feedback: (90)
TLH101's Avatar
Default RE: Large scale warbirds, best ARF for electric conversion?
Though a little smaller than what you have now, Kyosho has a line of 50 size electric warbirds that are very nice. http://www.kyoshoamerica.com/WARBIRD_c_74.html
Old 11-12-2011, 09:43 PM
tigermeet
I converted the ESM Skyraider to electric. Made a hatch right behind the firewall for the batteries. I'm running an Eflite power 160 on 10s (2 x5s) CC 85Hv speed control and a scale 4 blade prop. I can comfortably fly around on 1/2 throttle. With flaps deployed she lands almost like a trainer.
Old 11-19-2011, 11:09 PM
styk
Hi tigermeet
can you show us any photos of your hatch on the skyraider and what size 4 blade prop did you use
Regards
Styk
Old 11-21-2011, 08:36 PM
tigermeet
Here's the pictures you asked for. The prop is a Master Airscrew 15.5 x 8. It was the biggest 4 blade I could find without getting into the high dollar blades
ID:	1689677   Click image for larger version
ID:	1689678   Click image for larger version
ID:	1689679   Click image for larger version
ID:	1689680   Click image for larger version
Old 11-22-2011, 10:43 AM
RickAvery
Hi Andrew,
I've done hangar-9 Spitfire & P-40. The Spitty is a great candidate for a battery hatch. Here is a link to my hatch thread; http://www.rcgroups.com/forums/showt...ight=rickavery
The P-40 not such a good candidate as the space & bulkheads aren't as convienent for such. Both are wonderful fliers with power 60s on 6s. The Spitty has split flaps and lands like a feather. For fear of tip stalling, I land the P-40 a bit fast and let her roll out. The P-40 ended up almost 2lbs. lighter than the Spit although the dimensions are are very similar?? The flaps & servo on the Spit add some, not sure where the rest of it comes from. With identical power systems, the P-40 performs better, 2lbs really shows up. Unfortunately, hangar-9 has discontinued the P-40. I found mine on fee-bay. I think I'd like to do a skyraider as above. Good luck in your search.
Rick
ID:	1689858   Click image for larger version
ID:	1689859   Click image for larger version
ID:	1689860   Click image for larger version
Old 11-29-2011, 11:17 PM
orthodoc
Thanks Rick ,
saw your thread on the hatch cut out and build. Some nice precision work there. still havent decided but leaning toward the Spitfire. Like the hangar 9 as I know their stuff. The Kyosho 50 size Spitty looks nice on the website and some with a battery hatch. Working on some scale touches tom my Mustang so this will keep me busy for awhile. Man the ESM planes look great also - too many options!
