power setup 8-10 lbs warbird now possibly sport later on
my plan for power setup
power 60
http://www.horizonhobby.com/products...r-motor-400kv-
e-flite 60 amp esc
http://www.horizonhobby.com/products...s-esc-EFLA1060
-do I need to go 75amp esc just in case to avoid burning up the esc? I will be running 6S lipos
- what C rating do I need on the battery pack?
- are there any better places to buy this setup from?
power 60
e-flite 60 amp esc
RE: power setup 8-10 lbs warbird now possibly sport later on
Looking at the motor, it has the same specs as the Tacon 60, MP 60, EMP 60 motors. I have a Monster Power 60 in a low wing trainer I use for a glider tug. I use a 5500 6s battery, 18X6 APC "E" pro and get about 9 1/2 pounds of thrust. This only pulls 46 amp with a fresh battery static per my watt meter. Going to a 18X8 prop, thrust goes up to about 11 /3/4 pounds of thrust. and right at the limit of 60 amps.
With my plane loaded with a 2.3 meter 4 pound glider I am at almost 12 pounds flying weight. She takes off easy and climbs well. You r setup should give you just over a 1 to 1 power to weight ratio. It is not going to be any type of 3D machine, yet it should fly well.
I am running a 60 amp ESC with built in BEC in my plane. It runs (5) servo plus the release servo.
http://www.hobbypartz.com/07e06-proton-60a.html
http://www.hobbypartz.com/96m606-big...030-400kv.html
http://www.hobbypartz.com/mo604brmo.html
https://www.leaderhobby.com/product....=9394001224334
https://www.leaderhobby.com/product....=9394001224336
Buzz.
Buzz.
Thanks for the feedback, looks like the two most tempting motors (exceed rc and tucano) are sold out. bummer
I am waiting for them to come in again. If they do not show up soon I will order from Leaders. I have a couple orders and they were fast shipping and i got what I ordered.
Buzz.
Buzz.
I did a search for feedback on leaders motors and couldn't find anything, makes me nervous to buy stuff without feedback.
They are also sold at radical rc.
http://www.radicalrc.com/category/EM...ess-Motors-180
The motors may have 5oo different brand stickers on them. The blue ones look like the older Eflite copies or the Monster Power motors, I could be wrong though.
Buzz.
Buzz.
