Glow to Electric Conversions Discuss glow/gas conversion to electric here.
need answers please
Reply
Old 12-15-2011, 04:38 PM
Turqui
My Feedback: (139)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default need answers please
hi everibody, i have being a nitro guy all my rc flyer life,and lately i have decided to convert some of my planes to electric,so i need some advices please, and also i have a bunch of nitro items,engines all new in box wich i will consider trading if possible:
the plane i will like to convert first is a HANGAR 9 ULTRA STICK 40 SIZE ARF,at this moment y have a super tigre 45(nitro) mounted on it; so i need:
i need recomendations for reliable but economical items that i need to buy to convert this plane into electric, like motor,esc,charger,battery, i will like to get suggestions with specific details like models,manufacturers and places to buy so i dont have to guess, im very inexpierenced with electric planes.
if you have trades and are new in box,and need some nitro items,im open to deal.
here are the specs of the ultra stick 40:
Wingspan: 57.75 in (1467mm)
Overall Length: 51 in (1295mm)
Wing Area: 700 sq in (715 with quad flaps)
Flying Weight: 5–6 lb (2.3–2.7 kg)
Engine Size: .40–.46 2-stroke, .56–.82 4-stroke
Radio: 4 to 6 channel
Servos: 5 standard servos; 2 additional standard servos for optional quad flaps
Trim Scheme Colors: True Red (HANU866); White(HANU870); Black(HANU874)
Prop Size: 11x6 - 14x6
Hardware Included: Includes all hardware
Recommended Battery: JR 6-volt 2300 Ni-MH (JRPB5006)
Assembly Time: 7-9 Hours
Is Assembly Required: Yes
Turqui is offline
Old 12-31-2011, 12:41 PM
crazzyflyer
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: need answers please
For this size plane a 46 bl out runner would do nicely. Monster motor.com Cost adout $35.00 and there are more powerful motors for about the same price out there. 60 amp speed controller minimum E-bay $10-150 depending on the brand. Going cheep is ok. You just loose some efficiancy. 4,000 mah 5 cell 30-40c Lipo would work great-Hoppy People or Hobby King. Check my blogs for more info on e-conversions at www.modelairplanenews.com and www.crazzyflyer.blogspot.com Run a 12/8-13/8 two blade prop to keep amp draw in range.
Good flying
Romi
crazzyflyer is offline
Old 12-31-2011, 04:27 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Motor, they are out of stock but are suppose to be in?
http://www.hobbypartz.com/96m605-big...020-670kv.html
http://www.hobbypartz.com/monsterpow...ess-motor.html
ESC
http://www.hobbypartz.com/07e07-proton-60a-opto.html
Battery chargers
http://www.hobbypartz.com/60p-dyc-1004.html
If you want a AC/dc charger
http://www.hobbypartz.com/60p-dyc-1003.html
Battery
http://www.hobbypartz.com/98p-25c-4000-5s1p.html
This is so you can power the radio from the same battery as the motor or use a separate lipo battery to power the radio gear.
http://www.hobbypartz.com/ubube.html
plus you will need to figure out how to mount the motor to the front of the fuse.
Buzz.
blvdbuzzard is offline
Old 01-02-2012, 01:28 PM
nute12
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run a turningy g-46 brushless outrunner, plush 60 amp speed controller and a 3300 mah 4 cell 30c pack in my 4 lb 11 oz stick plane and it is crazy power using a 15/8 APC-E.
the whole conversion wad from HK was just over 100 bucks. Extra batts are 32 bucks each. I get 12 minutes hard flying. throttle management and easy flying should net quite a bit more time. probably have 40 flights on it now and not a problem.
nute12 is offline
