Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Sig Seniorita Glow to Electric conversion info needed
Reply
Old 05-21-2012, 12:03 PM
rcflyer1970
My Feedback: (212)
rcflyer1970's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Seniorita Glow to Electric conversion info needed
Hi, I have a 25 size Kadet Seniorita, I run a OS SZ-37 Heli engine with a 10x4 Prop, specs...Practical RPM range: 2000-21,000 / 1.4 HP @ 18,000 RPM
Weight: Total of power package ...glow eng, prop and silencer 13oz + 6 oz full of fuel
Total Airplane weight ready to fly 3.75 lbs
It hovers at 1/2 throttle and has great power and speed.
So my question, what would be a good Elec conversion Setup (Motor/Prop/ESC/Battery) that would match the performance I have now?
I have tried to figure it out but havn't been able to come up with a good package that I feel will work right.
Thanx in advance for any info.
rcflyer1970 is offline
Old 05-21-2012, 04:35 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Seniorita Glow to Electric conversion info needed
Not sure how much ground clearance you have but a .32 on 4s swinging a 13X8 APC E prop will do a fine job.
https://www.leaderhobby.com/product....42&Location=LA
https://www.leaderhobby.com/product....41&Location=LA
https://www.leaderhobby.com/product....02&Location=LA
This one with a 12X6 APC E prop
https://www.leaderhobby.com/product....03&Location=LA
ESC
http://www.hobbypartz.com/07e08-proton-80a.html
Battery
http://www.hobbypartz.com/98p-25c-2500-4s1p.html
Should give around 7 pounds of thrust or so. Per [link=http://www.s4a.ch/eflight/motorcalc_e.htm]ONLINE CALC PROGRAM[/link]
Buzz.
blvdbuzzard is offline
Old 05-22-2012, 09:24 AM
rcflyer1970
My Feedback: (212)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great info, looks like that combo will work out great. Thank's!
Old 06-22-2012, 06:31 PM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a Scorpion 3014-1040 on mine. On a 3S pack it flies very well. On my ARF version I use the Scorpion 3020-850 and 3S pack with 12X6 prop. I tried a 4S pack but power was up to over 800 watts, clearly too much for this plane. So I stay with 3S set up.
jollyroger is offline
Old 06-23-2012, 05:00 PM
DVI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built the Seniorita early this year. I made a hatch from the firewall to the landing gear mounting plate on the belly. The 3 cell 3600 mah battery mounts up against the firewall along the inside of the sidewall, (Mounting Plate Installed). I use an eflite power 15 and 40 amp speed control. This setup has worked well for me, I get 20 min flight times with about 1200-1500 mah to spare. I built this model for night flying by installing over 400 LED lights into the wings and fuselage. I power the lights with a seperate 1300 mah battery carried at the CG location. Very stable, Slow flying airplane.
DVI is offline
Old 06-23-2012, 05:30 PM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds cool. Got any pics?
