Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Sig Mid-Star 40 conversion
Reply
Old 06-28-2012, 12:53 PM
danf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Mid-Star 40 conversion
I started building a Sig Mid-Star 40 a few weeks ago and decided to convert it to electric... The plane is expected to be about 5lb (80oz) complete, so I initially started looking at 500W for power, but then I decided to add a little extra
I finally decided on putting a EMP C3548 1100kV turning an APC-E 11x5.5 with a HobbyWing Platinum 60A ESC and a Sky Lipo 4S 3300mah 20C battery. eCalc prediction is 730W max at 56a... This oughta scoot pretty good!
Now, a question for all you 'lectric experts out there... The ESC has a great big 'ol heat sink on it and I was considering cutting a hole in the bottom of the fuse to allow the heat sink to hang out in the air and cool a little bit... Is this a good or bad idea?
Also, I've noticed that eCalc has an option to describe your cooling setup as "very poor", "poor", "medium", "good", or "excellent"... I'm guessing that's all about how much air is flowing over the motor, but does anyone know what constitutes "excellent" or "good"? My motor will be mounted way out in front with nothing but the prop hub blocking airflow around it. The plane has cheeks on either side of the motor, but nothing above, below, or in front of the motor.
danf is offline
Old 06-28-2012, 03:44 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Mid-Star 40 conversion
I would say hanging out on the nose open all around would be excellent and if it was buried way back in a tight cowl would be very poor.
Sounds like you have a good setup. I say put the heat sink in the wind. Won't hurt anything.
Buzz.
blvdbuzzard is offline
Old 11-09-2012, 02:22 PM
n8rloves2fly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thinking of doing same convertion how did it work
n8rloves2fly is offline
Old 11-27-2012, 08:32 AM
DBono99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HI Did the EMP C3548/1100 give you the power you wanted..Seems alittle lite to be putting out 730 watts. Going to do a couple of 46 size converts, just looking for a good power supply.
Thanks Dan
DBono99 is offline
