Glow to Electric Conversions Discuss glow/gas conversion to electric here.
ProX 260 .90
Reply
Old 09-03-2012, 04:59 PM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ProX 260 .90
I'm converting my Prox 260 .90 glow plane to electric. It has a flat profile fuse, so how do I mount an electric motor to it in a sturdy way?
rem0.061 is offline
Old 09-03-2012, 05:55 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ProX 260 .90
If you look at how they did the small planes, you can do the same thing on a larger scale. You could also pin the ply mount the fuse with 1/16" dowels and glue.
http://www.nitroplanes.com/02a-016-y...epron-kit.html
http://www.nitroplanes.com/02a-014-m...epron-kit.html
Buzz.
blvdbuzzard is offline
Old 09-04-2012, 04:15 PM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a picture of the mounting area.
rem0.061 is offline
Old 09-04-2012, 05:45 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does the motor fit the cut out? If so you could cut a piece of ply to fit the s cutout and then use some triangle stock on the back side vertically to add strength.
Buzz.
Old 09-04-2012, 05:59 PM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It might need a millimeter or two shaved out to fit, but I also want the mount to reach around to the engine mounting holes, because fast tight 3D moves stress the mount alot from the gyroscopic resistance from the prop. I think I could just bolt a thick layer of ply in there like you said. I will be using a 4258 500kv motor, a 5000mah 6s lipo, and a 100A HK ESC. (one of the few conversions that costs less than buying an engine).
rem0.061 is offline
Old 09-05-2012, 04:21 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you used the X mount on the ply wood at the rear, the ply wood pinned and supported by triangle stock, it should hold as well as anything.
Buzz.
Old 09-06-2012, 03:23 AM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will find out towards the end of the month if it works.
rem0.061 is offline
Old 10-11-2012, 05:21 PM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finished the conversion and have pictures for anyone else interested in converting their Prox 260. It isn't the nicest looking setup but it should get the job done. I have not flown it yet.
ID:	1810406   Click image for larger version
rem0.061 is offline
Old 10-12-2012, 03:40 PM
rem0.061
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flew it today, it works. The ESC has less precise throttle in the upper range. It is nose heavy. I don't know how well the motor can handle the gyroscopic forces of 3D flying, the can/bell flexes. The 15x4W prop has just enough thrust to pull it up. It could probably turn a 16-17x4W at under 50 Amps.
rem0.061 is offline
