Glow to Electric Conversions Discuss glow/gas conversion to electric here.
DC-3 electric conversion
Reply
Old 09-19-2012, 11:00 AM
BOLT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DC-3 electric conversion
Hi there all of you fans of the watt and the volt:
I'm working on the conversion of a Top Flite DC-3 (8-10 lbs.) to electric. So far I have the motors (Turningy G46 a .46 glow equivalent) and the esc (Turningy 60A). Now, which battery size do I need to run those two motors for about 8 - 10 minutes flights? Although I'm an experienced glow pilot this is my first electric. Your assistance is really appreciated.
BOLT is offline
Old 09-19-2012, 03:55 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DC-3 electric conversion
Well if you look at this calc program, it give rough ideas of flight times. I have gotten longer flights then it lists. One said I would get about 17 minutes of mixed flying and i went over 30 minutes.
I have a Monster Power 46 with a 5s 5000 mah swinging a 13X6 APC E prop. I get 10 plus minutes of mixed flying easy.
The calc programs says 10 minutes on a 13X6, 12 minutes on a 13X5.
Are you setting this up with a battery per motor in each nacelle? or one central battery?
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz.
blvdbuzzard is offline
Old 09-20-2012, 02:18 AM
BOLT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your response Buzz:
I will be using two batteries, one per engine. This conversion will give me peace of mind by avoiding landing on one engine.
BOLT is offline
Old 02-02-2013, 06:41 PM
ANZAC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys, I'm doing the Topflite DC-3 electric conversion my self and I would like some advice. I have brought 2 x Turnurgy G-32 600kv motors,
2x 60amp speedys, 2x 4000ma 4 Cell lipos turning 13x8 props slightly cut down to clear fuse. Flat out each motor only produces 3lb thrust using about 35 amps or watts (I'm not sure). If this plane weighs around 10lb, will 6lb thrust be enough? Any advice wellcome, Regards Col Mitchell
ANZAC is offline
Old 02-06-2013, 06:21 PM
P-39 fan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello ANZAC, If your amp numbers are correct, you should be able to produce about 1100-1200 watts on your DC-3 on a fully charged battery. That would put you over 100 watts/ lb. Plenty of power for your plane. I would suggess you use a 30c or higher battery. You might want to experiment with a different size prop. Try a 12x9 3 blade and check youramp draw and thrust.
P-39 fan is offline
