Uravitch OV10 Bronco
I have an old Uravitch OV10 Bronco I was flying with two OS .25s.
Would like to convert it to electric. Weight is about 5.5 to 6lbs.
Need some recommendations for motors, esc, and batteries.
(economical please)
(economical please)
RE: Uravitch OV10 Bronco
This should do it. One ESC will need the red wire pulled out so only 1 BEC feeds the Rx or you can use ESC that do not have the BEC and use a battery to power the radio.
Run a 12X6 APC E prop and you will have a tiger by the tail.
Motor
http://www.hobbypartz.com/96m603-big...826-870kv.html
Battery (2) per flight
http://www.hobbypartz.com/98p-25c-2200-4s1p.html
Esc with BEC
http://www.hobbypartz.com/07e06-proton-60a.html
ESC without BEC
http://www.hobbypartz.com/07e07-proton-60a-opto.html
Buzz.
Motor
Esc with BEC
ESC without BEC
Buzz.
