Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Electric conversion advice please
Reply
Old 06-18-2013, 03:02 PM
bhoffo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Electric conversion advice please
Any ideas are greatly appreciated!
I have a 'Mach 1' model, a 63" span and 720 sq inch of wing area - a 'pattern' ship back in the day. Originally this was powered by a .60 engine with a 12 x 6 prop and performed quite ok until it hit the deck last week and smashed up the fuselage! This was due in part to the engine stopping at an unwanted spot mid-flight - and also pilot error!
So I plan to rebuild the fuselage and perhaps install an electric set-up but am wondering what system I should be putting in. I'm not flying the model in competitions - just sport flying with some easy aerobatics, so competition grade equipment isn't required; just something reliable.
The model weighs around 5-6lbs however I imagine with a battery that may come up another 1.5lbs or so, I also understand that it isn't ideal to deplete the battery below around 20% to prolong its life - so what length of flying time would I expect to get out of a new El setup?
Cheers,
Bruce - from Downunder
bhoffo is offline
Old 06-18-2013, 04:22 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Electric conversion advice please
Well you can use a large selection of "E" power now. Lost of good budget minded setup out there.
Motor
http://hobbyking.com/hobbyking/store..._60_Glow_.html
ESC
http://hobbyking.com/hobbyking/store...ontroller.html
Battery
http://hobbyking.com/hobbyking/store...Lipo_Pack.html
14X8 APC "E" prop, should give around 11 pounds of thrust. The cal program says 5 minutes of flight time. Said about the same for my 60 sized trainer I did. I had a flight of 35 minutes and the LVC did not come on. I was just at the limit right before it came on though. I was just doing touch and goes and easy flying. So I would say closer to 10 plus minutes of mixed flying.
Buzz.
blvdbuzzard is offline
Old 06-19-2013, 09:01 PM
bhoffo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Buzz,
Thanks for your reply and information - most helpful!
Cheers!
bhoffo is offline
