Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Global Superfly 15 size trainer..
Reply
Old 07-18-2013, 10:04 AM
magnumeng
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Global Superfly 15 size trainer..
Hello all,
I just picked up a lovely new in box Global Superfly trainer. I have everything to set it up for nitro but want to try something different this time. Looking for some recommendations for motor and esc to get the bird in the air with a 3/4s 4400mah battery.
Plane specs
Wingspan: 45in
Length : 35in
Weight: 2.75 pounds
Engine: .15
Desired Flight: Basic aerobatics
magnumeng is offline
Old 07-18-2013, 02:30 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Global Superfly 15 size trainer..
Only problem you may have is the landing gear may be to short for a 12X6 prop
Motor
http://www.hobbypartz.com/96m602-big...826-950kv.html
ESC
http://www.hobbypartz.com/07e05-proton-40a.html
Battery
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
Batteries have been out of stock for a long time, get them quick before they go.
Should have plenty of power and flight times around 8 to 10 minutes, depending on how much throttle you use.
Buzz.
blvdbuzzard is offline
Old 07-19-2013, 06:49 AM
magnumeng
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the recommendation. I have ordered the parts and a couple different props to see what works.
Old 07-19-2013, 04:42 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When working on the plane with the battery attached, please remove the prop. They can turn into blenders real fast.
That setup should give almost 4 pounds of thrust with a 12X6.
Buzz.
Old 08-17-2013, 08:03 AM
magnumeng
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally finished to build.. Here is what it looks like..
ID:	1909572   Click image for larger version
Old 08-18-2013, 03:35 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always liked those planes. I would like to own a new one again.
Is there a flight report yet?
Buzz
Old 10-14-2013, 11:00 AM
magnumeng
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Late flight report... The plane is still alive... Over all the plane flew very well... Felt a little heavy, but I think it was mainly due to it being nose heavy. not much room in the plan to relocate stuff.
Your power set up was spot on. I used a 9.5x7 inch prop to get the ground clearance. after about 5 mins of flying on a 3s 2200 battery, I only used 1400.
Old 10-14-2013, 07:49 PM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad I could help out. With what little you used, you should be able to get nice long flights in.
Buzz.
