Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Great Planes PT-60 Electric Conversion?
Reply
Old 08-22-2013, 03:08 PM
Foxbat711
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Great Planes PT-60 Electric Conversion?
Any advice on converting a Great Planes PT-60 Trainer to Electric? Thanks for any advice.....
Foxbat711 is offline
Old 08-22-2013, 04:22 PM
bassmanh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fox, we need more info..... Weight, wingspan, which wing ? flat built or with the dihedral ? ......
But with that said I think I would go with a .60 size eflight motor and there 60 amp esc with either a 5s or 6s pack ... or if it's light enough and you just want a basic Sunday flyer that can do a loop or roll here and there then I might use the e flight .46 motor and with the same esc on a 4 s pack but it would be a bit enemic tho....
Bass
bassmanh is offline
Old 08-22-2013, 10:33 PM
4*60
My Feedback: (41)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://hobbyking.com/hobbyking/store...ner_700kv.html
and 4S pack 5000mah
Something along those lines and inexpensive.
4*60 is offline
Old 08-23-2013, 04:09 AM
Foxbat711
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PT-60...... Wingspan: 71" Wing area: 888 sq. in. Length: 53.25" Weight: 7-8lbs. Airfoil: flat-bottom, but I will build the sport version with less dihedral.....
Old 08-23-2013, 04:42 AM
bassmanh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fox,
I think I would use a .60 size motor on 5s for that plane running a 13x6 prop to start since your building the sport wing.... here would be a good choice for motor as a lower price starting point = http://www.hobbypartz.com/96m606-big...030-400kv.html
and this esc would make a good combo = http://www.hobbypartz.com/07e-flyfun-60a.html
and I think I would use a 5s 5000 mah pack with this set up..... but the best thing to do is get yourself a good watt meter and test diferent props to what works best and keeps the amps where you need them.
bass
bassmanh is offline
Old 08-23-2013, 07:42 AM
Foxbat711
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you recommend a good watt meter?
Old 08-23-2013, 07:56 AM
bassmanh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only watt meter I have ever used is the astro flight ... But it worked very well and showed not only the amps but also the watts and volts . I think there around $50 to $60 bucks now....
Here is a link to one http://www3.towerhobbies.com/cgi-bin...?&I=LX3605&P=0
Bass
bassmanh is offline
