Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Problems with Glow to Electric Conversion
Reply
Old 03-05-2014, 08:01 PM
Crash Campbell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Angry Problems with Glow to Electric Conversion
Hi,
Long storey short. I'm replacing an OS 108 two stroke in a fun-scale Dynaflight PT - 19.
The motor is 5535-10 KV=230
Running on ten cells
Prop size recommended 20" to 22"
I'm using a 21x8 prop
I first used a Turningy 120AMP Speedy. It lasted about 6 flights before there was a loud pop followed by lots of smoke.
I replaced the speedy with a Hyperion Atlas 90 AMP opto
This combo runs to about 3/4 throttle then emits a loud screech and stops. If you close throttle and open again it works to about the same throttle setting.
Hmmmmm I though and tried another motor albeit 280KV with exactly the same result.
I've checked solder joints, timing, throttle delay and am about to check into a mental institution or go back to glow.
Does anyone have any helpful suggestions?
Many Thanks in Advance
Crash Campbell is offline
Old 03-06-2014, 08:58 AM
Dr Kiwi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How many amps does your Wattmeter tell you it is drawing? If you don't know that, you are in the dark. The 280Kv motor would draw a lot more!
The stopping and restarting after closing the throttle suggests an issue with the battery/LVC.
What happens if you reduce prop size?
Dr Kiwi is offline
Old 03-06-2014, 11:51 AM
Crash Campbell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I'll borrow a Wattmeter and check.
Thanks for the advice,
Cheers,
Old 03-07-2014, 11:54 AM
til
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wattmeter great idea , just a thought have you lengthened the esc wires to the battery?
Til
til is offline
Old 03-07-2014, 12:43 PM
Crash Campbell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Til,
Thanks for the tip. No lenght is unaltered. I've arranged for one of my mates to come over after flying on Sunday and he will put his Watt meter into the circuit and see what the draw is. I'll let you know how it goes.
Many Thanks,
Old 03-12-2014, 10:49 AM
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think your timing is off, have you programmed the ESC to the specified timing of the motor?
mattnew is offline
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check that you said you checked timing....thinking....
mattnew is offline
Old 03-12-2014, 01:59 PM
Crash Campbell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks for the tips. Health issues brought testing to a halt)(&*&^)(. I'll get back to you all when I've been able to check the Watt Meter.
Cheers,
Old 03-26-2014, 02:10 AM
LS1f
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you tried higher timing?
Knut I.l
LS1f is offline
Old 03-26-2014, 08:17 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
http://www.rcuniverse.com/forum/m_7100376/tm.htm
If you are going to put together custom combinations of motors, props, ESC and batteries you MUST have a wattmeter. Otherwise you have no idea what the system is doing. For what that ESC cost you you could buy a wattmeter.
Borrowing one if fine but get one for yourself if you will continue to put your own power systems together. It really helps.
aeajr is offline
Old 03-26-2014, 11:39 AM
Crash Campbell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'have purchased a Watt meter but spinal surgery has/is keeping me from my work shop for at least another week so I have yet to start the investigations. Very frustrating.
Cheers,
Old 03-26-2014, 11:41 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spinal surgery? Ouch! Speedy recovery!
aeajr is offline
