Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Carl Goldberg Chipmunk conversion
Reply
Old 05-08-2014, 11:44 AM
Bill Rademacher
My Feedback: (77)
Bill Rademacher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Carl Goldberg Chipmunk conversion
I purchased a used Carl Goldberg Super Chipmunk at a swap meet recently fro $30.00. It was missing the cowl. It had old Airtronics servos in it, complete with flaps. I swapped out servos and ordered a one piece cowl from Fiberglass Specialties. I repainted the canopy frame white.
I had owned a used one years ago and flew it best with a .91 four stroke motor.
For this one, I had the idea to convert it to electric. I got the idea after searching on the web and seeing how others did their conversions. There weren't too many to choose from.
I decided to put a hatch in the top just behind the cowling. I used small PVC downspout cut into a battery tray for a 6 cell. I made motor standoffs out of wood. I asked HeadsUp RC what to put in this thing, and it has the system they recommended. I can tell you it flies great off grass and has ample power for everything but hovering. I currently have a 16 X 8 prop, and I will soon go to a 17 inch prop.
1 | B-130 | Emax BL4030 400kv Outrunner Brushless Motor | $49.95 |
1 | H-115 | Sky Power 80A ESC with Switchmode BEC | $37.95 |
1 | F-656 | 22.2v 4200mah 50C EZ Flite Pro Lipo Battery | $78.95 |
maybe these photos will give someone else ideas.
billrad
ID:	1993550   Click image for larger version
ID:	1993551   Click image for larger version
ID:	1993552   Click image for larger version
ID:	1993553   Click image for larger version
ID:	1993554   Click image for larger version
ID:	1993555   Click image for larger version
ID:	1993556   Click image for larger version
Bill Rademacher is offline
Old 05-19-2014, 05:22 AM
Bill Rademacher
My Feedback: (77)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I have a few flights on this now, with the 17 inch prop. It has tons of power. I fly around at half throttle.
If you've never had a Goldberg Chipmunk, the plane flies like a dream. Extremely easy to land. Just like I remembered.
billrad
Old 06-07-2014, 12:24 PM
zeroback
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice plane! Had the control line version way back when, great flyer. I like those folks at Heads Up great service and their locals.
zeroback is offline
Old 06-08-2014, 06:38 AM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I loved my Chipmunk for the years I flew her. She would be as gentle to fly as any trainer, yet spin and snap with the best of them. Slow her down to where the wings are rocking yet still have good control.
I have been tempted to build another. I have a world models Chipmunk right now with a Magnum 91 in it. If I even did get another i would go electric with it.
I have this power set in another 60 sized plane we use for a glider tug. I can get over 30 minutes of mixed flying on this setup. I to run a 16X8 prop. Good all around prop for this combo.
Motor
http://www.hobbypartz.com/96m606-big...030-400kv.html
ESC
http://www.hobbypartz.com/07e06-proton-60a.html
Battery
http://www.hobbypartz.com/98p-25c-5500-6s1p.html
Buzz.
blvdbuzzard is offline
Old 06-08-2014, 09:42 AM
zeroback
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have not taken apart a Tacon motor but I have five or six Rocket motors from HP. They are an excellent set of parts, the windings from the OEM as typically found on lower cost motors was the weak link. I fixed that problem with some beefy custom winding. Don't get me wrong the motors ran fine out of the box. What a difference some good wire makes on a good set of guts. I'm thinking the Tacon motor may well be the same story. As an example the Rocket motor has .2mm stator lamination thickness, vs .35mm on a Suppo motor of similar size and cost. The more lams in the stator the more flux lines the more power (in a nut shell). It's a bit of nostalgia for me to see the Chipmunk still out there, some things do not improve with time. If your Tacon motor ever gives you a problem let me know. I'll give it a world class winding at no cost to you. I do it for folks all the time, I just like winding motors and the look on someone face when they open the throttle the first time.
zeroback is offline
Old 03-15-2015, 03:59 AM
Taildragger
My Feedback: (204)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a Goldberg chipmunk many yrs ago. It had an old K&B 65 turning a 13-10 prop. Flew like the dickens. I flew it so long it just latterly started falling apart. Loved it!
Taildragger is offline
Old 01-26-2018, 12:49 PM
thweekender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you guys think you could run a 4s setup on the chipmunk?
thweekender is offline
Old 01-28-2018, 10:13 AM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a little more information? 4s what? Need to know what motor, battery, prop you are thinking of running?
Why are you looking at a 4s setup?
As an example, this motor running on 6s uses a 14, 15, 16 inch prop.
GForce G60 Brushless Outrunner Motor (5065-400KV) - Outrunner for Airplanes - Motors - Power | Value Hobby
So, if you are dropping the voltage that much, you may end up with a 20-24 inch prop?
For giggles, I used the Turnigy, G60 motor on 4s. It takes a 23x14 prop to get 180 ounces of thrust. If you MUST use a 4s, you would most likely need way to large of a prop.
Buzz.
