Glow to Electric
FL
Glow to Electric
New to Electric is there a chart for conversion from nitro to electric . I have a OS 40 on a airboat and Cox .051 on a sailplane i would like change to electric.
Thank for input
Lester Burch
Thank for input
Lester Burch
Well sort of. Figure 125-150 watts per pound. I know that really helps right
You old o.s. 40, you can use a tacon 32, 12x6 prop, 4s battery, 60 amp esc.
049's, close would be a park 450 or so.
http://www.hobbypartz.com/86mb18-roc...10-1190kv.html
http://www.valuehobby.com/power-syst...0kv-motor.html
http://www.valuehobby.com/power-syst...outrunner.html
Might be a little small, but you don't need much for a sail plane.,
Here is a free online motor calc. It takes a little time, but you can put in different motor's, props. batteries and see what the increase or decrease will have on the power out put.
https://ecalc.ch/motorcalc.php?ecalc&lang=en
Buzz.
Buzz.
