Hustler Trainer to Electric help
Hi
I've been out of the RC world for 10 years and getting back into it using electric.
I ripped the old Glow engine out of the hustler we flew and put in a Astro cobalt 25 with 1.7:1 gearing. It flies with a 12x 8 prop for 5 minutes flat out but,
I have trouble trimming to stop it rolling right. I suspect I do not have enough down and right thrust as I built it with none when I mounted the motor (as advised - I think they thought an astro 25 was a little speed 300 motor). With full left aileron trim it flys well.
Can anyone enlighten a little further as a chop to the front to reset the angles of thrust is major but I'll do it if that is necessary.
Yes I have checked the wings and elevator and rudder and minimal twist etc that is in the wings would not produce the amout of roll that occurs.
Regards
Regards
RE: Hustler Trainer to Electric help
I have enclosed the front forming a second firewall that the motor and gearbox sandwich upto.
Packing washers isn't efficient as only 2 screws are used in the astro gearbox.
More important, what is the level of side and down thrust??
1, 1.5 2 or more degrees??
regards
regards
My Feedback: (21)
Therin lies the rub. You have to experiment with side and down thrust until you find what works best. It's different for every plane... I doubt you'll be terribly pleased with having to tear apart and rebuild your plane several times to get the right offsets.
How about a wedge between the motor and front firewall? All you'd need to do is elongate the mounting holes in the firewall a little.
Start with 2 degrees right and down, but some trainers need more.
