Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Converting a Big Stik .40 to electric
Reply
Old 03-01-2004, 07:56 AM
mikeb33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Converting a Big Stik .40 to electric
I love flying my Big Stik .40 ARF http://www.greatplanes.com/airplanes/gpma1220.html with a .46FX but I have really only been interested in electric for the past few years. So could this big boy be converted, or is it too heavy? Currently it weighs 5 lbs 11oz empty. The engine and muffler weighs about 1 lb and the throttle servo and RX pack weigh about 6oz. If I used an AXI 2820/10 with a 10X6 prop and 10 cells, do you think it would be OK? Any other power setup that looks better? OR is a big plywood plane a lost cause for a conversion?
MIKE
mikeb33 is offline
Old 03-01-2004, 08:27 AM
d_wheel
d_wheel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Converting a Big Stik .40 to electric
Hello Mike,
Here is how I converted mine:
http://www.rcuniverse.com/forum/m_12...tm.htm#1264820
I have since made a few changes. I bent the main gear down a bit, installed a longer nose gear, and changed to a 14x10 e-prop. The Stik now has more power than any I have flown over the years. I practice the IMAC basic pattern with it and it does them with ease. I fly it regularly and enjoy it even more now than when it was powered by glow.
Later;
D.W.
d_wheel is offline
Old 03-01-2004, 08:35 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 2820/10 and 10 cells is a good swap for a .25 powered plane, or a light .40 that'll be doing nothing but floating around. .40 planes that you want to fly like .40 planes really need a 16-cell power system. Check out the Jeti 45/3, or the AXi 4120/14.
Matt Kirsch is offline
Old 03-04-2004, 04:34 PM
halfandhalf825
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it would work but performance would be limited. i put the AXI 2820/10 in a Modeltech magic and it was ok. it just floats around but no vertical or anything. AUW was 4.75 lb.
halfandhalf825 is offline
Old 03-04-2004, 05:01 PM
mikeb33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW! A AXI 4121/14 with controller = $250
A Thunder Power TP8000-5S4P pack = $375
A $625 power setup is a little pricey right now.
I may just sell it and buy a similar type plane made for electric that is much light and then can use a cheaper power system. Maybe something like this: http://www.nesail.com/detail.php?productID=1376
MIKE
mikeb33 is offline
