Dazzler or Uproar Conversion
My Feedback: (13)
WA
I would like to convert a uproar or Dazzler to electric flight.I have always flown fuel planes and I think It would be kick to have a electric funfly plane.I use a magnum 40 on the one I have now.and it works real well.I want to be able to use full sized servos also.
The planes has a 48 wingspan and weighs between 3.5 and 4 lbs. I must tell you I am about as dumb when talking about electrics as they come,but I would like to give them a try with a little help.I don't have a lot of money so please keep it simple. Thanks
TX
RE: Dazzler or Uproar Conversion
Greg Covey has a web site with an absolute TON of information. Check it out at :
www.gregcovey.com/rc.htm
Hope this helps,
Ken
Hope this helps,
Ken
My Feedback: (21)
Is that 3.5-4 lbs ready to fly, or without engine?
A similar plane, but designed specifically for electrics, and a low-budget power system at that, is the Gary Wright E3D. It's about the same size as a Dazzler, but only weighs about 3lbs, ready to fly. It was designed around a $20 Kyosho Endoplasma car motor and an inexpensive 10-cell CP2400 NiCd pack. I believe the website is www.gwmp.net.
My Feedback: (13)
WA
The Dazzler is a 3.5 to 5 lb plane as stated at Tower Hobbies.I assume that is with the motor.Why I want a Dazzler or Uproar is I have owned them and they are a blast to fly.I extended the control services and and modified the tail feathers and I can hang mine with a 40.
Matt the web site that you gave doesn't come up,what is the sites name?
