Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Kadet Senior to Elec.
Reply
Old 06-14-2004, 02:34 PM
captjckirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kadet Senior to Elec.
Kadet Senior [kit built] from glow to elec. I have a Senior which I am considering changing to electric power. Kowning a little about electric, I need some advice. I do have a Butterfly that is elec. with a Phaser 30-3, a 45 ESC, and a nicad 8 cell pac at 2400 ms. Total weight is 5#s. It flys well. The Senior weighs dry 5.5#s. I would like to get around 10-12 min. flight time. Thanks for your help.
captjckirk is offline
Old 06-14-2004, 03:57 PM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Kadet Senior to Elec.
The Sig Kadet Senior will be an easy conversion to electric power. Just treat it as a .60-size plane and look for one of the existing conversions in the forums or in a review.
The AXI 4130 motor on GP3300 NiMH cells would be a cost-effective approach. It would work fine on 18-20 cells.
With the huge wingspan and wingarea, this model will be very forgiving if it is on the heavy side. Therefor, even an old-style Astro Flight 625G or 640G geared Cobalt motor will work fine.
Good luck!
Greg Covey is offline
Old 06-14-2004, 04:40 PM
captjckirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Greg, thanks for your reply. I went on the inter-net regarding batts, couldn't find any 18 to 20 cell 3300s. Dymond shows a 10 cell nicm at 3300. Would the 4820 carry the plane with that combonation?
Old 06-15-2004, 08:03 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Typically, you need to combine smaller packs in series. More commonly, you can find 8-cell or 10-cells packs at most battery vendors or you can make your own packs from single cells.
[link=http://www.flydma.com/batteries/batteries.asp?path1=batteries]Diversity Model Aircraft [/link] sells larger GP3300 packs up to 24 cells.
I'm not sure what a 4820 is...
Old 06-15-2004, 08:46 AM
captjckirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, meant AXI4120.
Old 06-15-2004, 10:40 AM
Greg Covey
Greg Covey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I think the 4120 would work ok on the Sig Kadet Senior.
You could use the following setup:
[ul][*] AXI [link=http://www.hobby-lobby.com/brushless_axi.htm]4120/14[/link][*] [link=http://www.hobby-lobby.com/motormt.htm#AXI1]PM41002[/link] Radial Mount Set[*] 16-cells of GP3300[*] APC [link=http://www.hobby-lobby.com/elecprop.htm]14x7 or 15x8[/link] e-prop[*] [link=http://www.hobby-lobby.com/jetiblue.htm]JESA40OP[/link] Jeti 40-amp Opto ESC[*] [link=http://www.hobby-lobby.com/ubec.htm]KFS001[/link] UBEC, or KFS003 or an Rx. Battery pack
[/ul]
The lower cell count will keep the weight down. I would also option for the higher current 70-amp Opto ESC if you can afford it. The JESA70OP will run cooler and provide a possible upgrade path if you decide on a 4130 motor later on.
Old 06-15-2004, 02:48 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To make a 16-cell pack, you would connect two VERY common 8-cell packs in series. Kokam makes series connectors, or you can simply wire your own using the connectors of your own choosing, OR you should be able to get one made for you custom.
Matt Kirsch is offline
Old 06-15-2004, 04:41 PM
captjckirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all your input. Looks very do-able. I added up all the gear, and it looks like it will take a Fathers Day,a Birthday, and maybe Christmas to get it all done. One more question...is there such a thing as an external charge jack? Thanks again, will let you know about the progress.
Old 06-29-2004, 02:06 PM
captjckirk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Greg, I now have all the equipment you suggested for the Senior conversion. However, the use of the 15/8 prop gives me no ground clearence, the 14/7 gives me just enough to clear the ground. Is there another prop dimension that would work? I fly off a grass field so I think the prop will be mowing grass. Thanks for your help. Joe
Old 07-01-2004, 10:28 PM
RandyL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe, There may or may not be some usable ideas from my convereted Telemaster of similar size. I paticularly like the sloped battery box I built. I take off the "windshield" and the battery pulls out the front without taking the wing off. A proper sized styrofoam block at the bottom of the battery box set the CG of the airframe. A chunk of foam rubber stuffed in front of the battery ( and slightly sticking out the air hole in the box ) hold the battery in place during loops and rolls.
http://www.flyinglindy.homestead.com/Telemaster.html
RandyL is offline
