Cox 049 to E-Power
Cox 049 to E-Power
I am interested in converting an 049 powered air boat to electric. I am not sure how powerful of an electric motor I need. I don't know what kind of thrust an 049 puts out. My boat is supposed to us a 6 inch prop. That will be a limiting factor to me with the electric motor because of the prop shroud. Could I use a three blade prop to get the same thrust at a lower RPM?
So basically, what motor and 6" prop will give the same power or thrust as an 049 with a two blade 6x3.5 prop?
If anyone knows how much thrust in grams or oz an 049 can put out, that would be helpful as well.
Thank you all for your insight!
Reuben
Reuben
My Feedback: (21)
RE: Cox 049 to E-Power
On an airplane, I'd normally recommend a gear drive with a much larger propeller. Those little 049 engines turn some pretty extreme RPMs, around 20000.
My first inclination would be to try an 8-cell battery with a Speed 400 motor and 5x5 or 6x4 prop.
