Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Cox 049 to E-Power
Reply
Old 07-20-2004, 08:39 AM
Tubes
Tubes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cox 049 to E-Power
I am interested in converting an 049 powered air boat to electric. I am not sure how powerful of an electric motor I need. I don't know what kind of thrust an 049 puts out. My boat is supposed to us a 6 inch prop. That will be a limiting factor to me with the electric motor because of the prop shroud. Could I use a three blade prop to get the same thrust at a lower RPM?
So basically, what motor and 6" prop will give the same power or thrust as an 049 with a two blade 6x3.5 prop?
If anyone knows how much thrust in grams or oz an 049 can put out, that would be helpful as well.
Thank you all for your insight!
Reuben
Tubes is offline
Old 07-20-2004, 11:48 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cox 049 to E-Power
On an airplane, I'd normally recommend a gear drive with a much larger propeller. Those little 049 engines turn some pretty extreme RPMs, around 20000.
My first inclination would be to try an 8-cell battery with a Speed 400 motor and 5x5 or 6x4 prop.
Matt Kirsch is offline
Old 07-21-2004, 02:18 AM
Henke Torphammar
Henke Torphammar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
there are several threads on this topic, search the forums and you´ll find lot´s of good info.
Henke Torphammar is offline
