Sig Kougar conversion
FL
I'm converting a Sig Kougar from glow to electric. The plane is 6 years old and had not flown for two years as I started flying electrics only. The goal was to mimic the glow performance while keeping the weight in check. I wanted to use as much stuff that I had on hand to reduce expenses. Spurred on by comments that it would be too heavy, I pressed on.
I started by stripping all the glow componnents out of the airframe and mounting the electric motor. I decided to use the glow mount beams and a set of clamshell mounts from MPI to mount the motor. A large hole was cut in the firewall to allow access and airflow.
John
John
FL
RE: Sig Kougar conversion
In order to mount the battery pack, I cut out part of the front former to allow the battery to lay flat on the top of the fuse using velcro to mount it.
FL
To give you an idea of the weight, I'll give you a table of weights.
Kougar before conversion (excluding receiver battery, fuel tank empty)
92 ozs.
Items removed:
.46 engine 15 3/4 oz.
Fuel tank 2 oz.
Throttle servo 1 3/4 oz.
Foam 2 3/4 oz.
prop/spinner 2 1/4 oz.
Old receiver 1 3/8 oz.
Total weight removed 25 7/8 oz.
Items added:
Jeti Phasor 30-3, Jeti 40p esc, prop, spinner, clamshell mounts 12 1/4 oz.
Hitec Elecrton receiver 1/2 oz.
325 mah receiver battery, switch harness 2 oz.
Total weight added: 14 3/4 oz.
Weight budget for flight battery: 11 1/8 oz.
Possible Batteries:
TP 3s4p gen 1 16 3/4 oz.
TP 3s3p gen 2 14 oz.
(2) TP 3s 2100 gen 2 10 5/8 oz.
John
92 ozs.
Items removed:
Fuel tank 2 oz.
Foam 2 3/4 oz.
Items added:
Possible Batteries:
John
FL
Testing four prop/battery combos were tested and three were flown:
Phasor 30-3
APC 11x5.5
TP 3s4p gen 1 pack
42 A
10.5 V
435 Watts
9800 rpm
71.8 watts/lbs
Although it flew, the speed was low andperformance suffered.
Phasor 30-3
APC 10x7
TP 3s4p gen 1 pack
10.5 V
35 A
375 watts
(no rpm- tach battery died)
61.9 watts/lbs
Flew much better but required 3/4 power and tended to flop out of loops. Model seemed heavy.
Phasor 30-3
APC 10x7
TP 3s3p gen 2 pack
10.3 V
37 A
63.8 watts/lbs.
Flew even better and I flew the model for 12-15 mins. Equal to a .40 size motor but I still want more.
Phasor 30-3
APC 11x5.5
TP 3s3p gen 2 pack
10.6 V
43 A
74.2 watts/lbs
Didn't fly due to stripped nylon bolt but this is pushing the phasor motor which is listed as a max continuous amperage of 35.
Phasor 30-3
APC 11x5.5
TP 3s4p gen 1 pack
42 A
10.5 V
435 Watts
9800 rpm
71.8 watts/lbs
Phasor 30-3
APC 10x7
TP 3s4p gen 1 pack
10.5 V
35 A
375 watts
61.9 watts/lbs
Phasor 30-3
APC 10x7
TP 3s3p gen 2 pack
10.3 V
37 A
63.8 watts/lbs.
Phasor 30-3
APC 11x5.5
TP 3s3p gen 2 pack
10.6 V
43 A
74.2 watts/lbs
FL
Wanting more power, I decided to ditch to Jeti Phasor 30-3 and went with a Mega Motors 22/30/4 and a Castle Creations phoenix 60 esc. The battery is a TP 4s3p gen 2 pack.
Here are the changes in weights
Removed Phasor/ added mega 22/30/4 0 change
Removed Jeti 40p/ added phoenix 60 +1/2 oz.
In addition, I replaced to heavy standard Dubro tires with lighter Dave Brown foam tires. Weight change -2 1/4 oz.
This brings the empty weight to a touch over 79 oz.
The battery pack weighs 19 1/2 oz.
Total flying weight is 99 ozs. (6 lbs. 3 oz.)
FL
Although I haven't flown to plane due to high winds, here are some performance numbers:
Mega 22/30/4
APC 12x6
14.0 V
46.5 A
631 watts
8700 rpm
102 watts/lbs.
Mega 22/30/4
APC 11x7
14.1 V
45 A
624 watts
9200 rpm
101 watts/lbs.
Mega 22/30/4
APC 12x6
14.0 V
46.5 A
631 watts
8700 rpm
102 watts/lbs.
Mega 22/30/4
APC 11x7
14.1 V
45 A
624 watts
9200 rpm
101 watts/lbs.
