Glow to Electric Conversions Discuss glow/gas conversion to electric here.
House of Balsa P51
Reply
Old 09-24-2004, 11:07 AM
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default House of Balsa P51
Just got one of these, if I dicide to go electric with this, what will I need, here are the specs:
P-51D
1/12 stand off scale
SPECIFICATIONS
Wing span 36 in.
Wing area 216 sq. in.
Wt. with radio 22-28 oz.
Wing loading 14.6-18.6 oz./sq. ft.
Fuselage length 28.5 in.
2-4 channel radio reqd.
Engine TD.051 - .10
Joe[8D]
Joe Ortiz is offline
Old 09-24-2004, 11:31 AM
stanger89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: House of Balsa P51
Not exactly the same, but I've got a Sig Wonder (~37" wing, 338sq in, ~39oz AUW) that I converted to electric and it flys great. Here's what I've got in it:
Mega ACn 16/15/4
Castle Phoenix 25
APC 7x6E prop
7 Sanyo 1700 sub-c
Pulls about 25amps for about 175W of power.
I generally fly it for 6.5 min and usually have 1-2 minutes of full throttle reserve.
I'd say the amount of power provided by that setup would be about right for that plane, but it would probably be a bit heavy. In that case I'd probably look at going with LiPo batteries to lighten it.
stanger89 is offline
Old 09-24-2004, 06:00 PM
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, those big battery pack weigh alot, I'll go with Li-Po's for sure.
Joe[8D]
Old 09-24-2004, 06:04 PM
stanger89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I'm planning on switching to Lipos sometime, I'm guessing that with the weight reduction I'd get unlimited vertical.
Old 09-27-2004, 01:11 PM
Darrell B.
Darrell B.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few pics of my 43" HOB P-51.
Power is:
AXI 2808/24
Jeti 18 Amp controller
Aeronaut 10 x 6 folding prop
Apogee 3s2p 1660 mAh Lipo
AUW is 28 oz.
This plane is very fast, and with full throttle for most of the flight it will fly for at least 10 to 12 minutes, 18 to 20 with some throttle management. It will do fantastic big loops, and with a lower pitch prop would have unlimited vertical. The motor never gets warm, and the batteries are warm but not hot after long flights.
Darrell B.
ID:	177366   Click image for larger version
ID:	177367   Click image for larger version
Darrell B. is offline
Old 09-27-2004, 01:43 PM
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That plane looks great![X(], btw, how did you mount the motor?
Joe[8D]
Old 09-27-2004, 01:53 PM
Darrell B.
Darrell B.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the kit, they had a light ply spinner ring for the nose. I used it for a template and cut the middle out of the firewall, which was 3/16. I found the center of this piece and drilled a hole for the prop shaft. Then drill your screw holes, and cooling holes. Don't forget the cooling holes, they are essential for an outrunner! Then I mounted this motor mount in place of the spinner ring, and used strips of 3/4 oz fiberglass about a half inch wide by an inch and a half long and some CA to reinforce the joint. It works great.
Good Luck,
Darrell
Old 03-29-2010, 09:15 AM
spaceworm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this the 1/12 scale combat plane? Did you increase the wingspan? How many channels are you using? I just got one at auction with an OS FP15 and AET on three channels. What performance should I expect?
Thanks.
spaceworm is offline
