Heathkit Commander Trainer Conversion Pointers Sought
MI
I have a Heathkit Commander Trainer R/C plane, Model RP-1173, which I purchased back in β82 when Heathkit was getting out of the kit business. It is an all-Styrofoam, MRC .15 nitro powered model that I never built. I tried to break in the engine but it never ran right so the thing got shelved and has moved with me throughout the years in its original box. I Googled this kit but came up with no hits. It has a 4β wingspan, with special anti-stall wing tips, high dihedral wing, ~8β cord and the fusalage is 30.5β long. It has a tricycle landing gear with a steerable nose-gear.
Iβm thinking of repowering it with electric and would like suggestions on how to go about doing this? I want to use it as a trainer and fun flyer. What size motor, prop and what kind of gearing should I try? I can shed weight by using smaller servos, making lightweight landing gear, etc. I want to do this on the cheap so brushed motor and NiMH power source.
Thanks for any help!
MI
RE: Heathkit Commander Trainer Conversion Pointers Sought
The plane is about 300 grams for the foam alone. Two servos, a receiver, ESC and flight battery would need to be added to that. A bit under 1 Kilogram? The original .15 glow engine spun a 8β X 5β prop, if thatβs of any help.
I have very little experience with electric planes but lots with electronics, motors, RC trucks and boats and the like. I have absolutely no qualms about this aspect of the project.
I know I said brushed but looking around Iβm thinking something along the lines of the AXI 2808/16 on 7 cells for about 110 watts max. Am I in the ballpark?
http://www.hobby-lobby.com/brushless-axi2808.htm
MI
After lots of web surfing, looking at planes with similar specifications, and a few email from a helpful fellow in this group, I decided on the following:
Ultrafly A/30/24 brushless motor & gearbox (400 size brushless motor good for up to 180 watts and ~80% efficient), Castle Creations Phoenix 25A controller, Hitec HS81MG servos, my old ACE R/C Radio and receiver and a KAN 1100 mAh battery pack. I will select the number of cells and prop to maximize the efficiency of the motor while maintaining maximum prop diameter. I already have the Ultrafly and controller in hand. I have never played with brushless and I decided this was the R/C craft to try it on. Itβs going to be fun!
