Glow to Electric Conversions Discuss glow/gas conversion to electric here.
help convert a Goldberg Skylark 56 to electric
Reply
Old 12-01-2004, 08:55 PM
CrashSwiftly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default help convert a Goldberg Skylark 56 to electric
I just picked up a Goldberg Skylark 40 Arf and seriously want to make it electric but I have NO idea what I need to do to accomplish this.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUU0&P=0]Skylark[/link]
None of my club members fly electric other than the TOY jobs like Parkzone J-3's -Don't take that the wrong way, I have one too and LOVE it but it's still a toy compared to the power of nitro.
I know it is now possible to take a nitro and convert to E without sacrificing performance so I figured this is a great plane to prove it with.
As this is the first attempt I have ever made to try electric I am tottaly lost so any and all advise is most welcome. I need to learn.
I want the plane to out perform a similar .46 glow powered plane and hope a flight time of at least 5 minutes is possible???
I have the triton charger so Li-Po is fine if needed and price isn't a limiting factor.
I have been told by everyone in my club that electrics absolutly WILL NOT make a glow powered plane fly any better than park style slow at best but I know it can... Please help me prove it to my club. Maybe more in my club will then try to learn before they bash.
Thanks!
Crash
CrashSwiftly is offline
Old 12-02-2004, 04:42 AM
Henke Torphammar
Henke Torphammar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: help convert a Goldberg Skylark 56 to electric
This will be fun!
I understand that you have been reading the forums a bit, as you posted very good info about how you want this convertion made
DonĀ“t say you have no ide how to do this, you already have a good charger, you know about li-pos and you know that price is the only limiting factor on the performance you want. so we have a good start here.
this plane on a 46 glow would probably fly about 60mph and have like 1:1 thrust/weight ratio. the avarage .40 plane weigh in at about 5.5lb + fuel. so letĀ“s say we want power for a 6lb plane.
watt/lb rule says 100watts/lb for 1:1 thrust/weight ratio, so we want about 600watts input. maybe a bit more.
which motors and battery can handle 6-700watts then... a 4cell li-po pack would provide 700watts at 50Amps which is good. so a 4s3p thunderpower 6000 would be good.
Then a motor for this.... there are about 100 motor that would fit this plane. (you want to swing a 14-16" prop)
Outrunners are quiet, durable while geard motors makes a bit more noise, are a bit more fragile, but deliver more power for the same motorweight.
AXI 4120/14, about 700watts with a 14x10, 15x7
Next step
Plettenberg Orbit 25-14 or 25-18 700watts 14-15"
My choice Hacker B50L 6,7:1 of a proper wind, swinging a 16x10 more fragile, but awsome power.
hope this helps.
Henke Torphammar is offline
Old 12-02-2004, 09:32 AM
CrashSwiftly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply,
I read up on the items you listed and think I may go with the AXI 4120/14 and Thunder Power 4s3p 6000MaH
If what I am understanding is correct, this combination should make the plane fly with at least the same authority as it would on a glow .46
What kind of flight time can I expect with this setup ?
Would a 4s4p simply extend the run time without adding to performance?
Also, (Sorry...Questions,Questions....) What controller would I need for this setup?
Thx
Crash
Old 12-02-2004, 12:45 PM
oracle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, check this review out. It's a electric conversion on a .40 to .46 Razor 3-D Flyer. [link=http://www.rcuniverse.com/magazine/article_display.cfm?article_id=272]http://www.rcuniverse.com/magazine/article_display.cfm?article_id=272[/link]
The review also has videos of the flight. Hope this gives you some ideas.
oracle is offline
Old 12-02-2004, 03:35 PM
Henke Torphammar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Yeah a 4s4p will extend the flight time, also make the avarage C lower (still 50Amps, but larger capacity, less load/cell)
I have not run the AXI my self but looking at the numbers it should work well, motocalc says 6.16lb thust and about 45amps with a 14x7. could probably go 15x7 too, or 14x10 if you need more speed. IĀ“m pretty sure it will perform like a hot 46 or ordinary .60
search the forums for this motor and see what you find.
flight time would be somewhere around 20-30min on a 4s4p depending on how much you use the throttle.
