Building a C123 Provider
HI
Aloha, Is anyone building/flying the C-123 Provider from Palmer Plans? I started building the C-123 two months ago and thinking of converting this to electric using two Axi 40XX. I got some questions on building and flying! Mahalo.........Hank
My Feedback: (21)
RE: Building a C123 Provider
You've come to the right place for powering the plane. Building and flying, you might find someone in this forum, but you stand a much better chance in the Scratch Building forum for that...
Anyway, what are the vital stats on this plane? Number of engines/motors, weight, size, etc..
HI
Thank you for pointing me into the right direction. The Provider is a 1:12 scale, 110" wing span, 1223 sq. in., 75.75" long and the target weight is 14lb 10oz. using two O.S. MAX .61 ABC. 7 Channels, flaps, retracts, and loading ramp. The conversion from the two .61 gas will be two AXI 412014. Here's a question, being that this plane will be using 12 servos, what kind/type of batteries should I use for the receiver? The servos are all digital and I know they will be using power all the time.
ORIGINAL: hvendiola
http://www.rcscalebuilder.com/forum/...sp?FID=22&PN=2
My Feedback: (21)
The 4120/14 is a good choice for getting 700+ Watts x2, which is what you'll want for a 14-15lb "heavy-metal" scale airplane. 16 NiMHs or 5S LiPoly, propped for 40 Amps peak... You'll have a winner on your hands.
