DynaFlite Butterfly 99 inch (Endoplasma Powered)
RE: DynaFlite Butterfly 99 inch (Endoplasma Powered)
http://www2.towerhobbies.com/cgi-bi...?&I=LXE616&P=ML
I Helped out a buddy that has this kit and covering the wings and the FUSE.
WOW, is this a large Park Flyer or what?[:-]
Yes, I saw a thread link, evaluation of this model indicating that the first couple of kits had a problem with the dye balsa, however, the later kits came with great improvements.
Here's the review for your reading pleasure....
http://webpages.charter.net/rcfu/Ki.../Butterfly.html
I did not build the wings but, rather covered them....
ME
I will be converting my Butterfly to electric too. I have been reading your posts on the other forum too. Can't wait to fly it.
amitysanimal
amitysanimal
I have a Butterfly that I occasionally fly with a .19 glow engine. I would like to convert it to electric so I could use it in an area that is noise sensitive. I am not knowlegeable on electric power and would like to know what size motor, esc, and battery combinations would work short of going brushless which I can not afford. Thanks to all that can find the time to contribute to my question. Dave
IA
Hi Dave, I would suggest that you check out Gliders And Sailplanes, there are several posts regarding electrifying the Butterfly. I would be happy to e-mail some pics showing my conversion if you are interested.
TX
I am in the process of rebuilding my almost 20 year old Butterfly after crash last year. The wing and tail feathers survived but the fuse did not. I did not pay much attention to the parts when I picked up the pieces. I need to know the distance from the bulkhead at the leading edge of the wing to the firewall.
Thanks for your help in advance,
Patrick
Patrick
Mark finally flew this model Monday (08-02-2010) and did so for 20 minutes with 3-Cell Li-POLYs and he had to reduce propeller size.
Weather was just perfect and the translucent covering looked great in the air!
Just a wonderful model.
I like the colors. I love these power gliders. I built the Butterfly last year and had an os25fx on the nose. One flight and I knew I had to go elecric. I have since built the Piece o cake and have an E-flite park 450 in her. But I am still itching to finish the elec. conversion BF. I have an Eflite power 15 going on the Butterfly, she may take to the air this weekind!
Its always great to see other builds of the Graceful Butterfly! and it little sister.
ORIGINAL: ejam
Carlos
ID
Love the color scheme! My dad has a Butterfly that he built back in 1978 and has hundreds of documented flights. Who knows how many people have learned to fly with it, but it's got to be around 50 or so.
It's had a O.S. .25 engine, but will be converting it to electric this winter. Hope we have as good of results as you guys have.
The older kits (Marks Models and earlier Dynaflite) turned out lighter, but it's still an excellent design.
