Don Smith KI-61 Conversion Questions
My Feedback: (106)
I am looking for ideas on this possible conversion.
I am considering powering a Don Smith KI-61 with electric instead of gas. This plane has not been built yet. It has a wingspan of 85 3/4". The root span is 16 1/2", tip span is 7 1/16". I have been told that these will come in anywhere from 16-22lbs. The plans call for a SuperTiger 2500, others have been seen with an OS 160.
The reasons that I am looking to electric is to not have to cut up the cowl and to make it easier to deal with from a cleanup perspective.
FL
RE: Don Smith KI-61 Conversion Questions
Along this line, a gentleman on ezone converted a World GS Zero with a Hacker C50 XL running on 10s at I believe 2200 to 2500 watts. An AXI 5330 series would also work. A big Actro would also. Mainly you would be looking at about a 2000 to 2500 watt setup. It won't be cheap, but still could be easily done.
John
John
My Feedback: (106)
I did some checking with hobby-lobby on the 5330/18 and a 10S. What they stated was "According to the ElectriCalc program that I trust, you can only run a maximum of a 20x11 prop. This should yield about 1911 watts at about a 72-75 amp draw. (237 oz. of thrust) I show that the maximum amp draw for this motor to be 75 amps. (I realize that the catalog shows a 91 amp draw but the motor would not tolerate this but for a few seconds.)"
I appreciate there willingness to help (and will continue to work with them on options), just looking for other opinions as I don't want to spend twice on a motor for this conversion.
Any thoughts? Maybe I should be looking at a different motor? Thoughts on whether an Actro 60 would work? I appreciate any help that is offered.
Hi Bob,
I agree with John's recommendations.
The weight and size of your KI-61 is similar to my 33% Edge 540. Here is the setup I am using. You will not likely find a more cost-effective combination than the AXI/Jeti setup.
[ul][*] AXI 5330/18[*] Jeti JESAP90PW Advance PLUS 90 ESC w/Program Card[*] APC 21" prop[*] FMA Power Force Regulator[*] 10s Lithium pack
[/ul]
Good luck!
[/ul]
Good luck!
My Feedback: (106)
John/Greg/HobbyLobby -- Thanks for all of the help.
I am going with an AXI 5330/18, JETI 90 Opto and a 10S3P setup. In looking at some of the prop options, it looks like I may start with a 18x10 that should put out approx 1900w drawing 62A and pushing 334oz thrust. If the calcs are right, I should have more than sufficient push for a scale warbird to operate with extra throttle to use as necessary.
Should be a great project for this fall and on.
It's a linear regulator that provides 10amps at either 5v or 6v to power your servos and receivers. When you start using big servos on these giant scale planes, the standard UBEC 3-5amp output doesn't cut it. A linear regulator, although heavier, also provides noise-free power like a battery. When you use the Power Force regulator, you don't need to use a separate receiver battery since everything runs off the main flight pack.
Note that the Power Force regulator works on a 2s-4s Lithium voltage so your 10s3p single pack will be too much voltage. My Edge 540 10s pack is split into a 4s and 6s combination.
CA
For what it is worth I have discovered that Hobby Lobby likes to exaggerate their claims on the AXI motors. I bought the AXI 4130/20 for a Rascal 110 running a TP 8S4P 8000mA Li-Po with a 17 x 10 APC prop. The end result was burning up 2 AXI motors, great warranty! I ended up getting their 5330/18 using the same ESC Jeti 77 and 8S4P 8000mA Li-Po and 20 x 11 APC prop. This combination gives me 1400 watts at 47 amps, both motor and ESC ran nice and cool. The performance flying the 15 pound Rascal 110 is great!
Monte
Monte
