Brushless Twin Battery??
My Feedback: (8)
Hi Guys,
I'm thinking about converting a Hobbico Twinstar to e-power. I want to use to 2 bl motors each with their own esc. Now, should I use 1 main battery for both motors or should each motor have an individual pack. I was thinking that 1 main pack would be better. anyone have any experience with brushless electric twins?????
RE: Brushless Twin Battery??
Either way will work. In the case of the Twinstar fuselage, I would suspect that a single pack for both motors would be easiest.
My Feedback: (72)
rfg06,
Go to "Electric , General Discussion" and search "Counter Rotating Props" (don't ask) to see my conversion on the Hobbico Twinstar.
I used two Axi 2820-10 motors, two Jeti 40 amp controllers. a 3S3P 6000 Li-Po battery and APC 10X7 E. props.
The problem I have is the battery runs too hot running two motors, around 140 to 150 degrees, 135 is max with the 10X7's and when I use 10X6's I lose performance so I'll will soon be installing a pair of battery's, one for each motor for a cure but don't know which battery's yet.
I'm using the same setup in my Urovitch OV-10 Bronco with the same problem.
My Feedback: (8)
Hi guys,
Thanks for your help Greg & Carlos and nice job on the conversion Carlos!!! I will definitely check out the thread detailing your conversion.
