Funtana 100X Landing Gear
FL
Guys
Does anyone know if the LG for the Funtana 100X is taller than that of the Old 90? Is the bolt pattern the same? The Guy at Horizon was very helpful. He said probably but wasn't sure of either question.
StephenT
StephenT
GA
RE: Funtana 100X Landing Gear
The bolt pattern is the same. Taller. I will have to go out to the shop to check. The Wing tube does NOT fit. It is way to small in Diamater.. Length is OK. It was 1 Oz. Lighter!!
YES.. It is taller by 1in. Maybe 1.5
LATER
LATER
My Feedback: (38)
If you are having ground clearance problems like I did when I converted the X to electric, Graphtec makes a c/f gear which is much stronger and about 2" taller. I have to run a 24x10 apc. Even with the elevated Graphtex gear and 4" tires, my clearance is minimal.
Just for you info.
Paul
Just for you info.
Paul
i can not find replaceament landing gear for my X100.
anyone have any idea where can i get it ? (original/aftermarket)
thanks!
thanks!
OH
The gear that I got with my Funtana 100 was very "cheesy" and snapped on the second landing when only high grass snagged it. I got a new one from GrapfTech. Very nice.....
