52"depron spitfire help please get off ground
hope someone can help
i have build a 52" spitfire out of depron.
it weighs in about 1050gm before battery
this plane is a copy of a greatplanes spitfire that ran 46nitro motor in it.( witch now hangs in the back room as it is to nice to crash )lol or im to scared to fly it lol
i have a 5000kv and a 4200kv motors
also have 30amp 40amp and a 80amp ESC
also the props i was thinking of using where a 10x8 or10x6 ep props
NOW the question is can i use this stuff one this plane or what would be the right setup for this plane or prop
As i have tried the 5000kv and the 30amp esc with the10x8 prop and i fried the ESC in about 20 sec
have i overloaded the motor with prop pitch or size
WHAT have i done wrong or could have been a stuffed ESC in the first place
please help a old petrol head turn elec
please please dont tell me to go to motocalc as this just confuses me more lol
ive been to motor calc but i must be doing something wrong there too
please please help
please please help
RE: 52
Dude ... the motor is WAAAAAAAAAAYYYY too hot! KV amazingly too high. Let's say your plane is 1 kg and with the motor etc it would be about 1.75 kgs and you want to fly her scale.
Motor - something in the 450W-500W range ... try the DualSky 3542 or 3548 series ... AXI 2820 series ... Hyperion 30XX series and other which are the same.
Batt - 3S 2,200 to 3S 2,500
ESC - 40A
Prop - 11x8 to 12x8
ESC - 40A
Prop - 11x8 to 12x8
RE: 52
thanks
also the whole plane plus motor etc weighs 1050gm but yes you are right plus the battery is about 1156gms
so really im looking for something like this motor
Rpm/kv: 1100KV
Weight: 74g
Motor Dimensions: 35*30mm
Shaft Size: 4.0*49mm
Prop/ Recom: 9x5/10x4.7
Battery: 2-4Li-Po
Idle current: 1.0A
Load current: 10A
Power (Watt): 315
ESC (A): 30A
Ri (?): 0.077
Pull (Approx):510g
or is the pull to low
Rpm/kv: 1100KV
Weight: 74g
Battery: 2-4Li-Po
Idle current: 1.0A
Load current: 10A
Power (Watt): 315
ESC (A): 30A
Ri (?): 0.077
Pull (Approx):510g
RE: 52
Scale flying means to fly like the real thing. That would basically mean she will not give you vertical flight like the Space Shuttle ... What is the weight of the bare plane, plane alone without MOTOR/BATT/ESC but with servos and UC adn wheels etc. We can estimate from there.
RE: 52
ill check now for you about the weight
ooh scale flying ..well if thats the case i would really want it a bit farster than scale ... lol a vert climb would look nice
RE: 52
motor i think i will use is this one
TURNIGY AerodriveXp
Model: TR35-36C
Input Voltage : 7.4V~11.1V (2~3S Li-po)
Kv : 1100rpm/V } within 10%
Current capacity : 35A/30s
Dimentions : 35mm X 36mm / 1.38in X 1.41in
Shaft diameter : 4mm / 0.16in
Weight : 106g / 3.74oz
Number of poles/magnets : 14
Recommended model weight : 1000~1900g / 35~67oz
Power equivalent : .25 to .30 IC glow engine
Stator Dimentions: 28x14mm
Power: 400W+
TURNIGY AerodriveXp
Model: TR35-36C
Power: 400W+
