electric conversions
Hi
I am new at this electric bit What size and type of electric motor should i use to change 25cc IC motors I have a transaal and I am thinking of putting electric motors in it Thanks for any help
Darryll
Darryll
NJ
RE: electric conversions
You gotta look at the weight of your airplane to figure out what size motor you'll need. I really like the Horizon Hobby Eflite motors because they're so easy to select based on weight/power requirements. It can seem overwhelming at first, until you get a couple motors and try them in different airframes with different props/batteries. Not sure what a transal is, but if it has a .25, this should work for you. http://www.horizonhobby.com/Products...odID=EFLM4025A
I also really like the Hacker series motors, good power and they're supposed to be really efficient. Some might argue they're all basically the same though.
