Saito 150 - Worth Fixing
my Saito 150 died today... in a catastrophic way... see pics.
it threw the valve cover, rocker completely off and the piston exploded. that's as far as i have gone with it. bearings are free as anything on the bottom end.
My Feedback: (16)
RE: Saito 150 - Worth Fixing
Henry gave me a old style big head Saito 120 once. It had dropped a valve and Horizon wouldn't fix it. Lucky there was no collision
The engine was 20 years old at the time and had a lot of neglected hours on it. When I last saw it running, he was using a 14 X 8 prop on it.
Examining the engine internals, the clearance ramps on the cam were beat up indicative of excessive valve lash and high rpm. The tips of the valve stems were peened over also indicative of a large valve gap and high rpm.
I repaired the engine with a spare valve retainer C-clip from the junk box and it then had good compression.
I gave the engine to Bill Roberson.
My Feedback: (16)
Banned
WA
ORIGINAL: w8ye
Post was not editied by moderator
Banned
WA
ORIGINAL: w8ye
That 150 appeared to have a few running hours on it.
It looks as though it dropped an exhaust valve first
My Feedback: (16)
ORIGINAL: Konrad
So the peened stem kept the valve from dropping all the way into the cylinder (hung up on the valve guide)? Did you have to clean up the stem to remove the valve, if it was bent? If so how? If you reused the valve did you have to true up the retainer grove? If so how?
ORIGINAL: w8ye
I fiddled with it some to determine that the valve nor the quide were bent.
The engine was consumed in a house fire at Bill Roberson's a couple years later.
