FURY TWIN Cylinder Engine
Ive been doing research on a engine that I just got the other day. Its not complete but I would like to hopefully find the missing parts. Can someone tell me more about this. All I know is that it I think itis an outboard engine for a boat. Engine needs center carb asem, crankshaft and what ever else that gets attached to it. How much is this worth in its current condition?
RE: FURY TWIN Cylinder Engine
They show a number of the different Sea Fury engines here, both inboard and outboard.
You might want to try and contact some of the guys mentioned in their website:
http://modelenginecollecting.com/Eng...-outboard.html
If it is the .12 engine, it may be closer to complete than if it is a outboard or a inboard/outboard model.
These engines were usually tethered to a cord and run more or less like a control line airplane, but on the water.
Sometimes they would fix the rudder at angle and let them run in circles, but they had the tendency to not follow perfect circles though and get way from you.
IN
I had the Fury Twin Outboard,Complete,Sold it to a collector in Michigan,
He told me it was woth 500,00 when I spoke to him but following year I
took it to Toledo and he backed down but stiil got $300.00 out of it,Not
bad as I got it for nothing,
