Best 1.2 Four Stroke
Old 12-09-2010, 06:05 PM
ron9844
My Feedback: (65)
Default Best 1.2 Four Stroke
I am looking for a new 1.2 Four stroke, Which is better Saito or OS.
Ron
Old 12-09-2010, 06:28 PM
earlwb
earlwb's Avatar
Default RE: Best 1.2 Four Stroke
It really depends on your usage, how comfortable you are with a particular brand, and the airplane design you plan to install the engine in.
But when it comes to push and shove, I prefer the Saito engines myself.
But I do have several different brands of 4 stroke engines. They can all be useful in different applications. One brand may be better for a certain application over the other.
Old 12-09-2010, 06:45 PM
spaceworm
I have and love Saito, but you might want to look at Enya and Magnum.
Sincerely, Richard
Old 12-09-2010, 07:17 PM
solarviper
My Feedback: (139)
the saito 125 is an absolute beast of an engine, they produce tremendous power, i should know i have 7 of them
Old 12-09-2010, 07:23 PM
ton2di
My Feedback: (182)
Can't go wrong with either one of them (OS, Saito) as in your original choice. Have both the Saito125 and OS 120FSIII and they both perform well. Saito weighs much less though, but it also has the breather line that sometimes gets more oil to the plane compared to the OS.
Old 12-09-2010, 07:53 PM
solarviper
My Feedback: (139)
yes he's right on that one! if you don't run a piece of fuel tubing from the breather nipple to outside the planes, they will pump all kinds of oil out of them and make a mess, i have forgot to do that many times [:@]
Old 12-09-2010, 08:40 PM
mike109
mike109's Avatar
G'day I have a few OS four strokes which I like, quite a few Saitos which are great but I really like my Laser Four Strokes. Laser make a 120 and a 150.
www.laser-engines.com
Actually, it really depends on what sort of airframe you are going to put the engine into. If weight is a concern, then Saito. If clean running matters, then the Alpha OS engines and if bullet proof reliability and very easy handling matters then it is the Laser. The Laser also does not need Nitro and does not need muffler pressure and really likes to be mounted inverted.
Oh, I also have two Enyas but they are in the smaller size range. I love them too and I have had quite a few ASP and Magnum four strokes as well (1 at the moment) but I never seem to become really attached to them and end up selling them on. The one ASP I do have has leaky valves though it runs OK (but for how long I wonder). It is not very old.
OK, I like all four strokes.
Old 12-09-2010, 08:41 PM
NM2K
My Feedback: (14)
ORIGINAL: earlwb
I'm just the opposite and lean toward the OS for a 1.20. I love Saito engines too and have a bunch of them.
Ed Cregger
Old 12-09-2010, 09:50 PM
Campgems
I've got a couple saito 150s and a 180, which are 120s on steroids. I also have a couple O.S. 120 surpasses, a one and a two, both pumpers. The O.S pump is a big problem for parts in later life., other parts for that mater, where the Saito parts seem to be avaiable and usually in stock.
As pointed out, the Saito is a lighter engine. Both brands run well and idle very well, the saito is a bit better in this catorgry.
It was pointed out above that Magnum might be considered. I have several of their smaller four strokes and they are good running engines, but check the weight of the 120, it is considerably heaver than the O.S 120 if I remember correct. It's been a couple years since I checked.
The Saitos are more dificult to time the cam, but not impossible once you pick up the tips. I've rebuilt both the Saito and O.S engines and while the configuration of head and cylinder is different, both are easy to work on. Valve adjustments are the same, and tuning the carb is about the same in the non pumped versions.
A couple of our guys fly YS engines and swear by them once they are running. Once in tune, they seem to b e rock solid.
Don
Old 12-09-2010, 10:34 PM
NM2K
My Feedback: (14)
ORIGINAL: Campgems
Don
I used to fly YS, until they went to requiring high nitro and costing just shy of one thousand dollars. It's just a hobby folks and it isn't worth the money that they cost to own and operate these days, as far as I'm concerned.
I don't fly 1.20 sized 3D models, so a few ounces difference in weight is of no significance to me. I buy Saito engines in spite of their ugly looks, when I buy Saito. I prefer the looks of OS engines and their clones. Just a personal thing with me. If the Tower conglomerate gets any more ridiculous with their prices, I won't be buying OS any longer. Magnums work just fine, thank you.
Ed Cregger
Old 12-10-2010, 07:04 AM
ron9844
My Feedback: (65)
Thanks for all the reply's. I will be using it in a pattern plane called the Tiger Tail 4S and another called the Tar Baby.
Ron
Old 12-10-2010, 08:56 AM
NM2K
My Feedback: (14)
I wish you had mentioned the type of model that you were going to power a bit earlier. The Saito might be the best coice for high performance flying, but either brand will work well.
Ed Cregger
Old 12-10-2010, 09:01 AM
mike early
mike early's Avatar
The saito 125 is a good engine. best power to weight available. But probably not the most powerful.
Old 12-10-2010, 09:04 AM
Kostas1
Kostas1's Avatar
Although i don't have many years of experience with 4-strokes,
my old SAITO FA-120S is a *performer*
Old 12-10-2010, 09:24 AM
spaceworm
Like my my 120ABC with air-bleed carb, except mine has gold rocker covers like yours. Heavy though! Thanks to KMOT for pic.
Sincerely, SPACEWORM, Saito Club #635
Old 12-10-2010, 05:04 PM
ThumbSkull
My Feedback: (57)
ThumbSkull's Avatar
My opinion of the best 120 four stroke is the YS110. Slightly more power than a 120 or 125 Saito or Magnum. The OS110a is nice for pattern as well but I still like the YS.
Old 12-11-2010, 12:30 AM
Kostas1
Kostas1's Avatar
Why do you limit the 110FS-a
only for pattern use ?
Old 12-11-2010, 05:35 AM
ThumbSkull
My Feedback: (57)
ThumbSkull's Avatar
ORIGINAL: Kostas1
I didn't.
I limited my response to pattern use because ron9844 (the thread starter) ask the question as it pertains to his pattern plane.
Old 12-11-2010, 11:59 AM
Pippin
I would also consider the all new O.S. FSa-155P. It's lighter and more powerful than the old 120FS.
http://www.os-engines.co.jp/english/...alog/35430.htm
The new O.S. alpha range runs very clean. No mess like Saito.
Old 12-11-2010, 05:53 PM
freakingfast
The YS-110 is very strong and economical if you run a Merlin #2009 plug, than you can run 15% nitro fuel instead of 20 or 30% and get a low reliable idle and practically no power loss at WOT. Runs well inverted with this plug too.
Old 12-11-2010, 08:20 PM
w8ye
My Feedback: (16)
w8ye's Avatar
This is a repeat of several other posts in this thread.
I have five Saito 125's. I use them in bigger 60 size airframes. They have the same foot print as a OS 91 Surpass and the Saito 100.
Takes around four gallons to get one to were I consider it to be fully broken in. I run 16 X 6 and 17 X 4W APC props. I have several Twist 60's and a You Can Do 60 that I use them on.
Old 12-12-2010, 02:18 PM
Pippin
...how about the TT F-130S?
The new O.S. 155 is rated at 2.6HP! There is an Enya 155R too. http://www.stevewebb.co.uk/index.php...F&area=Engines
Lots of choices for sure.
Old 12-13-2010, 12:15 AM
Kostas1
Kostas1's Avatar
So the 2.6hp is much ?
What's the hp a SAITO FA-180 makes ?
Old 12-13-2010, 04:52 AM
ThumbSkull
My Feedback: (57)
ThumbSkull's Avatar
HP ratings are irrelevant for model engines comparison because there are no standards or supervision in testing.
There are .21 sized engines rated over 3HP but it's pretty easy to see that wouldn't be enough engine to pull a 10lb. plane off the ground.
Old 12-13-2010, 09:39 AM
NM2K
My Feedback: (14)
ORIGINAL: ThumbSkull
The real limiting factor when it comes to large four-strokes is the smallest prop you can swing, because the large four-strokes can swing some serious sized lumber.
Ed Cregger
