Carb with Label
Carb with Label
I've got a TN Carb from Ebay, it's labeled "NS". Want to know where it is coming from...?
Kind Regards,
Holm
Edit: The article number was 150533091783, there is still a picture..
Kind Regards,
Holm
RE: Carb with Label
That's a carb from a Bluebird engine (sold in America as a Brat). I have a 51 and 28 with a similar carb except neither of mine have the recess which is probably to help hold an air filter. Both the 51 and 28 have a 13mm spigot but the barrel size is 5.5mm for the 28 and 7.8mm for the 51 so I suspect the 8.7 figure given is a typo and they got it backwards.
RE: Carb with Label
No, the 8,7mm is correct, measured this now. I've primarely bought it to test it on the "Old Soviet Union Raduga 0.60 Engine" '(or so), but the carb from that thing is working in the meantime (since I've made a new LS needle).
The Spigot is something between 12,91 and 12,96mm (not really that round anymore), I must make an adapter to fit it on the 13,4mm Bore from the Raduga (Rainbow).
Thank you!
Holm
Thank you!
Holm
