Radial made from single cylinder engines
Quite some time ago, I came across a site where someone had made a radial engine by mounting 5 or 7 single cylinder glow engines around a central shaft. Each engine drove a gear which meshed with a larger gear on the central shaft. I was wondering if anyone knew of this site or info on something similar. Not that I want to build one, I just want to see how its done.
RE: Radial made from single cylinder engines
