Best engine per $ ever
I bought some scrap engines from mecoa, and I think I did good
One K&B 65 sportster for just $18, one GMS 73 for just $25 and one piece of crap for ??$
The K&B was just clean up, put some shim on the crank(to much end play) and a muffler from my K&B 61 and a spare parry carb.
It did 11200 rpm with a zinger 11x6, 7900 rpm with a 14x6 and 10000rpm with a APC 12x6, I'm happy with the engine, so easy to start
And I ran it on 80/20 castor only fuel.
I found a new piston for the GMS in New Zealand and a new muffler for just $18 NZ$
Good deals are out there if you are willing to work :-)
RE: Best engine per $ ever
I remember being given a Fox .45 RC engine by a fellow modeler many years ago. He said Fox engines were crap and no good, blah blah blah. I cleaned it up some. Fired it up on my test stand and adjusted it. It was running good, so I mounted it in a plane and went flying with it. Five planes later and it is still working just fine. Looks a little cruddy with the old castor oil backed on it, but it still runs great. I figured it would be due for new bearings soon, but it is still hangling in there.
I had bought a GMS 1.20 from someone a while back real cheap, they had used red gasket sealant all over it. The only problem I found was the remote needle valve was sucking air or allowing the fuel to vaporize and bubble inside the fuel line. so I only needed to use a different carb or a different remote needle valve. it worked fine with a Perry carb and the GMS carb worked fine with a Fox remote needle valve.
This was when it had just about worn out a HobbicoStartFire low wing plane
The old Fox 45 is now on a Combat Airmadillo 40:
a long time ago, my apartment was burglarized and they stole most all of my RC planes and equipment. Someone gave me a Fox .60 Bluehead engine to use on a plane as well as a MRC four channel RC system too. I ran the engine and radio in a Astro-Hog for a long time, and then the engine was used on a couple of other planes. I shelved the engine for many years as we needed to use mufflers and it didn't have one. But more recently I pulled the engine back out of the box and mounted it on a new Tiger 60 plane and it flies just fine once more. I did put in new rings, but the bearings were still OK.
Ihave gotten some screaming good deals over the years. The last swap meet Iwent to I bought a complete ready to fly Carl Goldgerg 20 with a like new radio and engine , the engine turned out to be an OS26Surpass. You wouldnt believe how much I paid for it, lets just say it was a really really good bargain.
My Feedback: (14)
To me, the best engine per dollar would have to be the McCoy .35 of the late fifties/early sixties? Or perhaps the Cox .049 Babe Bee of the same era. Nice engines that were financially accessible (I got my Cox .049 engines out of neighborhood trash cans a week or two after Christmas).
Ed Cregger
Ed Cregger
This was my best bargain, an OS 40VF for $10 and I was the only bidder, I guess because everyone else was turned off by the horrible paint job on engine and carb and the head being fitted wrong. I figured that even if the engine was totally worn out then at least I'd have a spare crankcase and other minor parts. Stripped it, the paint came off in a few minutes, gave it a good clean and reassembled because everything looked fine. It started first flick and ran as well as my other 40VF's .
ORIGINAL: NM2K
Ed Cregger
Ed Cregger
It was a major effort to buy my first Fox Stunt .35 way back then as I had to save and work a lot for it, and even then it took all my money.
I did the same thing on acquiring Cox engines too.
